p.s. I've already read Nick's saga with his head gasket, and I'm hoping that my problem is something else...
I have a day to fix this before I move back to Sydney to start uni...
The enmity I feel for my car at the moment is unparalleled. Here's the problem: I've recently replaced the radiator and fitted a thermofan and overflow tank, which both are working fine to the best of my knowledge. The problem is... on long highway/city runs, the car often overheats - slowly, nothing violent, but enough to necessitate stopping and letting it cool down before proceeding...
I've found that removing the vacuum tube from the advance mechanism on the distributor helps to slow this overheating down, but it still happens...
Perhaps the worst part is that this doesn't always happen. For instance, driving from Sydney to Mittagong today, I had to stop once at Wattle Grove, where I let it cool down, then I had to stop at Mount Annan, where I let it cool down and refitted the vacuum advance tube as an elimination, then again just near the Picton exit, where I let it cool down and removed the vacuum advance tube again, and after all this it finally ran cool enough to get me all the way home, even having the audacity to cool down enough for the thermofan to switch off when I was about 1km from home.
Some things I thought might have been the cause:
1. Ignition system - I doubt this because as much as I try to get the correct ignition timing, it still happens
2. Radiator cap - I doubt this because I replaced it two days ago and it still happened today
3. Thermostat - I'm planning on checking this out after having a very late lunch. If it's stuffed, I will take action, and if there's no bleed hole I'll add one. It's a genuine Nissan one though, and only a year old. It should be okay.
4. Loose tappets - there's been an unnerving noise coming from the rocker cover for at least two years now, which I suspect to be loose tappets but really I have no idea. I will check this out later today or tomorrow, provided the next option wouldn't be more likely...
5. Head gasket - well after reading Nick's saga, I suppose the cause could be a bad head gasket. I would really rather that this wasn't the case, but if there's no other alternative then I suppose I have to.
Please tell me what you think.
