It is currently Thu Jan 17, 2019 9:39 pm
 Post subject: How To build a Grunter
PostPosted: Sat Sep 11, 2004 6:16 pm
Ok,
Who out there knows how to build a true grunter, i mean, 2.4 litres, L20 block with ? crank etc etc. I am after some motor combinations for rally use, does not necessarily need to be PRC specific i.e L18 block but am open to suggestions.
PostPosted: Sat Sep 11, 2004 6:25 pm
http://www.ozdat.com/ozdatonline/enginedesign if you want to play with combinations.
http://home.att.net/~jason510/Motorspecs.htm for some ready-to-go formulas.
http://www.google.com where you should've gone first.
http://ozdat.com/forum/search.php where you should've gone second.
Dave
PostPosted: Sun Sep 12, 2004 9:19 am
Of course, you can always give Locky a call at Nissauto in Ferntree Gully. :D
Chris [;-{)>
PostPosted: Sun Sep 12, 2004 10:17 am
'Mal' from ozdat could probably help you out there, he had an L20 block bored to 2.4 with all the goodies for sale not long ago.. Wish i was a bit older so i could have bought it!
We have that datsun difference!
1971 Datsun 1600
PostPosted: Mon Sep 13, 2004 12:04 am
i thought you could only bore out a l18 block to 2.1L max?
how much could u bore it? so you caqn make a grunter motor using a l18 block?
Building a Datsun 1600 hopefully it will be finished this century............ L18 SSS motor with trx wheels
PostPosted: Mon Sep 13, 2004 9:57 am
The largest capacity I have seen out of an L18, is a tad over 2.3L! :shock:
This requires both boring and stroking the engine, which means a lot, and I mean a LOT, of machining of the block to fit a Z22 crank and and a few other parts. I only know of 2 of these motors ever. The bore is still around the 89mm mark but the stoke is longer...
http://www.capitalsteering.com.au - Steering you in the right direction
http://www.fifthgear.com.au - Get the Driver's Edge
PostPosted: Mon Sep 13, 2004 12:34 pm
damn 2.3L !!!
it would require alot of work i guess. so ill stick to my 1998cc motor iv got plans for
i found this article about stwart wilkson
Using an L18 block rather than the more common L20B blocks used in Grunter Mk.1, this work of art churns out 220 horsepower on the dyno, thanks to a meticulous build, twin 48mm Webers and a special Collins-built two and a half inch set of extractors.
The current motor, thanks to some very innovative work on the crank and rods, is out to 2400cc. You get the impression that Collins is reasonably impressed with the new engine - he tells us that it's so tractable that you could even use it to drive to the supermarket in!
the full article is here
http://www.rallysportnews.com.au/cms/A_ ... ticle.html
i wish i had that motor in my datto would make historic rallies fun to say the least.
maybe if you want a stoker you should contact stwart wilkson he sounds like to be a real pro at datto engines!
PostPosted: Mon Sep 13, 2004 2:26 pm
Sure stroking a L4 will give you lots of low down grunt but you aint gonna be able to rev it that far!!
I would think that 7000rpm would be about the safe limit!
So there goes all the hot cams with long durations and 8000rpm+ redlines!
Could stick with a Datsport 25/65 Cam!! they rock and are good for about 7000rpm! will lots of low down pull.
Also Z22 / Z24 cranks are sh*t when compared to the factory L4 crank.
It would seem that they are not fully counterweighted like the L4 jobbie.
L18's will rev harder than a L20 !
More revs = more power
More Power = more fun
