R30Rally,
If you are going to extract power through high-revs, I'm pretty sure you ARE going to get increased wear on things, simply as everything is rubbing more, or are you saying Honda/Toyota have discovered a frictionless substance for their piston rings/cam lobes?
This is a compromise. You are sacrificing engine-life for power. It may not be much of a compromise depending on the amount of engine-life you sacrifice, but a compromise it is none-the-less.
As for statement 3, I wasn't talking about your sportivo engine. I was using an extreme case as an example, as in extreme cases, the effects are more obvious, but can potentially be related/indicative.
Bob,
No they aren't race motors, but nor are they `run of the mill' engines either. They seem to be somewhere in between, hence the reliability/longevity for performance would logically be somewhere in between too? Oh and I wasn't saying BELIEVE the rumour I referred to, I was trying to stimulate discussion about it - thanks beef. I like debate/information myself.
Dave
I see the point your trying to make in relation to rpm versus engine wear, though I don't agree that on average these late model (approx 2001 onwards) require any extra rebuilds than the run of the mill stuff.
Example ford barra 4.0 xr6 turbo. ( I know it's not exactly the same example but I'd rather talk about stuff I know about, rather than bullsh*t).
I meet the head engineer that worked on the turbo project for ford australia and discussed at length the engine life (and testing involved) of the turbo 6 ford. He said without question the turbo motor (and turbo) is designed and built to last, at minimum, for the same amount of km's as the standard ford six and they actually test the turbo motor more thoroughly to ensure this is the case.
As much as I've love to have the same discussion with the equivalent toyota guy re the sportivo motor I doubt that will be possible, though I find it hard to believe the engine in the corolla would require any additional rebuilds in the life of the car as an example (I'm sure the same applies to the honda motors.
Also lets bear in mind were not talking about L-series produced in the 70's, engine manufacture has come a long way in 30 years. Note; I'm not for a second bagging an L-series as I own one, just an example.
Anyway, again this is just my opinion based on some facts and personal experience. Just for the record though I'm not some corolla or sportivo nut it just happened to be the best buy, by far for the price.
I would put my money were my mouth was in relation to a s2000 motor'd 16 if I had the time and the motivation to do it, pity I'd be special.
