It is currently Fri Mar 29, 2024 9:32 pm
 Post subject: Z--->L
PostPosted: Sun Aug 07, 2005 2:22 pm
can a LSeries head bolt directly unto a Zseries block??
Performance wise can a Z18 out perform a L16 in Aspirated form??
thanks...
"Loyal To The Game..Against All Odds!!"
PostPosted: Sun Aug 07, 2005 4:45 pm
yes an L head can bolt to a Z block. L and Z blocks are just about identical.
a Z18ET turbo will outperform an L16. a carby Z18S will have no more performance than an L16.
1971 Datsun 1600 - Z18ET
1996 Suzuki RGV250 VJ22
1996 Suzuki RGV250 SP VJ23
PostPosted: Sun Aug 07, 2005 6:55 pm
I asked a similar question a few months ago and got these responses.
http://ozdat.com/forum/viewtopic.php?t= ... harger+z18
PostPosted: Mon Aug 08, 2005 12:45 am
thanks... will the head need any mods at all??
PostPosted: Fri Sep 02, 2005 10:30 pm
Location: Darwin. Home of the Rice Car ShitHeap Lancer/Excel and really gay numberplates.
nope. but while its off, its a good idea to get it reco'd with new valve guides and stem seals. Not expensive, and the cam/rockers/towers are super easy to R&R. Depending on your budget, you might get some mild porting/cleaning up done.
Errol from Datrats has some George Fury cam grind information available . http://www.datrats.com.au
The z18et twin butterfly throttle is body is often replaced with an rb30et or xf falcon which I believe requires some cutting and welding.
Specialised Power Porting in Victoria do some wonderful things with the intake manifold, but its big $.
FJ20t injectors are a direct fit and a cheap upgrade in terms of flow. Just need the right sized grommets.
550cc 13bt are also dirt cheap, but you may want to get some barbs machined into the oring fitting if you use the stock fuel rail. Other wise a custom unit is the go.
Have a look for cracks around the rear-most head bolt seats.
Aaron
