Facts as they stand: 1970 Datsun 1600, L20B engine, 60 thou oversize, L18 Head. Had a Crow Street/race cam originally, a Series II Bluebird Electronic Dizzy, a T04 Turbo (marked with A/R 65 if I remember correctly) Drawing through a Zenith SU type Carby. Motor's not decompressed, that doesn't seem to be a problem. I run it on Premium and it doesn't ping. Pretty low boost and revs.
I stumbled accross the kit a while ago and it was a rushed fitting just before I moved for work, so I haven't had opportunity to troubleshoot. But now I'm back and not sure how I should proceed.
It worked but initially it was a pig until it 3000rpm, and I mean I was feathering the throttle to keep it going at all. Then it would start pulling at 3500 and hit the 5 psi max just over 4500 and then the revs would slow down. (but that's another story, doesnt matter what I have done to this motor has never reved, cams, carbys, even this turbo) I was thinking it might be the N/A hot cam. So I changed that back to standard. Now it starts behaving at 2500 pulls a bit earlier but doesn't reach max boost. (the other cam obviously allowed the motor to pump more air)
I think it could be just my carby, but this is my first experience with Turbos so I'm not sure where to go next. I'm in two minds as to whether to stay with the Turbo and start troubleshooting or go back to the tried and proven 42mm DCOE's that I have, before I waste more time and money.
But even this experience has given me the taste of the Fun Turbos can give.
I welcome any opinions. I know there have been plenty of Turbo L series threads in this forum. I have browsed to try and find some info. Maybe somone can point me in the right direction
