A few things I have found with my car.......
Toe - depends on how the car turns. If you dont have any understeer, its actually nice to run some toe in. 1-2mm either side (2-4mm total) is good. Reason for this is, as the cars front end squats under braking the the wheels will toe out. So if you start with some toe in you can get it nice and straight under heavy braking. If however you are suffering from lack of turn in (understeer), then some toe out can certainly help.
Camber - depends on the tyre. I used to run 5 degrees with the A032 Yokohamas, but when we went to the A048's only needed 4 degrees at the most. Again, the less camber you run the better the car feels under brakes and less chance of locking a front under heavy braking. Best way to tell is with a pyromoter immediately after you come off the track. Measure in three places across each tyre (Inside edge, centre & outside edge). If the inside edge is higher than the rest you may have too much camber, if the outside is higher, you may need more camber. If the centre is higher your tyre pressure is too high.
Castor - The sunny has 6.2 degrees of castor. If i drive at any less than 90% the front end will shake so bad it has actually ripped the wheel out of my hands! Castor however in a lot ways is more beneficial than camber, so the more you can run the better (but the steering gets bloody heavy at slow speeds). On the street though, you probably want to stay around 4-5 degrees if you can get away with it.
Lastly, don't forget about your tyre pressures. Measure them as soon as possible after coming in off the track. You will find they work best at a certain pressure. For the A048s on my car 32psi was the magic number. If they were higher when I came off the track I would adjust them while they are still hot. This meant that the car a bit sloppy when you first hit the track next time round, but when the pressures come up it was great. After you have you get them to the right point, check them once they have gone cold (next morning is best) then you can right the numbers down as a starting point for the next time you attaned the track.
Hope that helps,
Mark.
_________________ www.full-throttle.com.au
www.boostcooler.com.au
When the Flag drops........... the Bullshit stops
Go hard or go home!
