You actually shim the top
control arm kit in. Use 720FWD top bolts and made up 10mm spacer.
As you lower a 720 the camber increases to positive.
if your gonna lower it make sure it doesnt tuck tyre, I get defected all the time in my lux cause I was almost tucking rim but now im not tucking tyre and I dont get touched, my old mans a cop and they dont have a eyebrow height for dato's cause they are too old, bag it so you can go as high and as low as you want
Yeah bagging it will certainly see it off the road if you get caught. They dont engineer bags any more here. =(
If you're running an SR, no doubt you will try to drive it slideways. So give your back and your dato some form of suspension travel.
My 720 is as low as you really want to go. I still retain some suspension travel and so far havent been given a second look. As nicholls suggests, leave a gap between the tire and arch. My 720 is bright yellow with charcoal painted 80 series Surf steel rims (heavy as) with lowish profile tires and white walls. Along with a z18et. I have tire/arch gap, so far so good. Plus it has made using the ute still viable.
But then again you still cant go past this one. I have this set to my desktop.
http://image.automotive.com/f/images/99 ... riding.jpg
Thanks for sharing the picture with us. It looks great. I figured it was a matter of loosening the bushing and re-torquing them to adjust the height.
