It is currently Thu Apr 18, 2024 7:12 pm
Post new topic  Reply to topic  [ 6 posts ]
 Post subject: 240k inserts into 180b.
PostPosted: Sat Jan 21, 2012 9:49 am
Hey guys forum member has some green tokico's at a good price, will they fit? I'm running I think late model the 180b struts that have the vl caliper fitting. I don't have car or easy access to car atm is the diameter the same, longer shorter? ta
PostPosted: Sat Jan 21, 2012 10:15 am
Old Digger
From memory the 180b struts are slightly longer than the 240k. If the inserts are shorter drop the right amount of 20 cent coins in the tube to space them out. If they are too long them I would look for something else as the gland nut needs to bottom out in the tube. The diameter and thread is the same. Make sure you drop a big of oil into the tube before you put the inserts in.
1928 Model A CC Pickup
PostPosted: Sat Jan 21, 2012 12:14 pm
Guru
From the Monroe cattledog:
180B - Type T4, Body length 413, Comp. length 413, Extd. length 599mm.
240K - Type T4, Body length 404, Comp. length 404, Extd. length 687mm.
Just to clarify, the gland nut SHOULD NOT bottom out in the tube.
You need to add a spacer at the tube bottom to bring the strut body shoulder to where the stock insert would sit, e.g. at the same level as the strut tube top.
That will allow the gland nut to clamp down on the top of the insert in a positive fashion.
Do a dry run and mark where the gland nut runs out of thread.
As long as the finished assembly is above the mark you know that the insert is well clamped and won't rattle around inside the tube.
As suggested, oil up the tube.
I leave the oil from the old wet struts in the tube, slip the insert in and let it displace the excess oil, then tighten it all up :thumbsup:
Regards, Graeme
Just trying to help...
http://nissanman.shutterfly.com/
graemes@internode.on.net
PostPosted: Sun Jan 22, 2012 10:03 am
Thank you graeme should be pretty good dude. I think I have about 50 mm chopped out my struts for the coilover should work without a spacer hey?
PostPosted: Sun Jan 22, 2012 10:15 am
Guru
Well, there is only a 9mm difference in body length so that is far short of the 50mm of which you speak :?
Regards, Graeme
PostPosted: Sun Jan 22, 2012 1:40 pm
Old Digger
:lol:
