irs 200b rear sway bar http://www.ozdat.com.au/forum/viewtopic.php?t=32272 |
Author: | 2EASY [ Wed Jan 15, 2014 11:48 am ] |
Post subject: | irs 200b rear sway bar |
Anyone know if there's a bolt in option ? Iv fitted a r31 front sway bar and while it feels more stable it understeer more and have lost the turn in that the stock bar had hopefully there's a rear bar to even it out otherwise stock bars going back in. |
Author: | Markus [ Sun Jan 19, 2014 12:38 pm ] |
Post subject: | Re: irs 200b rear sway bar |
There are standard 200b rear sway bars. Hard to find though |
Author: | green200b [ Sun Jan 19, 2014 3:08 pm ] |
280ZX ones fit 200B SSSs but they do have a few differences in the rear end. Might be worth a shot though? Markus, which 200Bs had rear sway bars? I don't recall any of mine ever having one. |
Author: | svd001 [ Sun Jan 19, 2014 4:40 pm ] |
Yep, 280zx alright. Grab the pins, bar and hangers it will all bolt up. |
Author: | Markus [ Mon Jan 20, 2014 6:52 am ] |
Not sure exactly which. I think some of the coupes had them. Either way there is one in my garage waiting to be fitted again |
Author: | exarch [ Mon Jan 20, 2014 3:42 pm ] |
I know the 300zx rear sway bar will fit a 180b sss, you need to weld some tabs onto the rear cross member. so if the 180b sss and the 200b are similar this could also be an option |
Author: | 180BSSSt [ Tue Jan 21, 2014 12:59 am ] |
I installed a hollow Z31 300ZX rear swaybar in my 180B SSS. Sits below the crossmember and trailing arms so it does slightly compromise the ground clearance. I wouldn't do it to a rally car but it works nicely in mine (I have heavier springs, custom valved Konis and a heavier front swaybar). Cheers! |
Author: | Super [ Tue Jun 24, 2014 1:41 am ] |
Hi 180BSSST, Im interested in installing a rear sway bar into my 180bsss and didn't think you could till I read this thread. what's is involved in installing the Z31 300zx... what mods are needed? does a Z32 rear sway bar fit?? Can you post a picture to show how low to the ground it sits and where the mounting points are? your assistance would be appreciated Cheers |
