I'm Wiring in a used common internal reg bosch alternator(from stanza) to my 1600.
I have a B+ terminal a D+ terminal. And another + small terminal.
I have hooked up the main wire to the B+ and the lamp light wire to D+ terminal.
But the dash charge light won't come on when the ignition in turned on and the alternator won't charge when I actually start the engine and have it running, But if I touch power to the D+ terminal, the alternator will kick in and start to charge.
What am I missing??
_________________ When the sign says "don't feed the bears", man you better not feed the bears.
