So recently I had to do a head gasket replacement on the L18 in my girlfriend's 180B. In the process of the uninstall and reinstall of everything the wiring coming from the thermostat housing has become damaged and broken off. I highlighted the part in question. There were two wires coming out. One going to ground and the other into the wiring harness. I thought the stuff around them at the top was solder and so I stripped the old wires back and went to resolder them to their terminals. The stuff isn't solder though. I think it's some kind of rubber? Didn't smell great when I chewed into it with the soldering iron though. Can anyone give me advice on what I should do to fix this? Do I need to purchase a new terminal section with the wires already in it (I noticed it is a screw in fitting into the housing) or is there a way for me to reattach the old wires?
Cheers.
Jimmy.
