Alternator holy grail http://www.ozdat.com.au/forum/viewtopic.php?t=34404 |
Page 1 of 2 |
Author: | Niscomm [ Thu Dec 08, 2016 7:02 pm ] |
Post subject: | Alternator holy grail |
Hi I'm new to the forum and I've been looking for an alternitive upgrade to my 40 amp alternator with not much success, scouring through books, Internet forums,word of mouth, and also your blogs on the subject so after being totally confused as I think a lot of people out there are I came across the perfect swap, I have a l20b in a 62 Commer camper with a BW 35 3 speed auto , dual battery setup and all the usual electronic gizmos drawing a lot of power. I came across an alternator from a Nissan patrol Y61/GU TD42 97-07 , J1147, 100 amp. Which was almost the easiest retro fit I've done on the van to date. The body is exactly the same I just had to ream out the bottom holes to suit a larger bolt connect the wires and I was done, from 40 amp to 100 amp and charging out at 14.5 amps. Just thought I would share this with all concerned. I will upload some photos once I know how any help with this would be great, Cheers |
Author: | Niscomm [ Sun Dec 11, 2016 9:13 am ] |
Post subject: | Re: Alternator holy grail |
I have been trying to upload some photos of the alternators to no avail, can I get some help with this. Thanks |
Author: | SR20Datsun [ Mon Dec 12, 2016 9:21 am ] |
Hello Niscomm, It may be easier if you use an outside image sharing website such as photobucket. |
Author: | Mr Camouflage [ Tue Dec 13, 2016 12:00 am ] | |
Post subject: | Re: Alternator holy grail | |
Some tips on image uploading http://ozdat.com/forum/viewtopic.php?f=4&t=27289
Thanks |
Author: | Niscomm [ Tue Dec 13, 2016 1:22 pm ] |
Thanks I tried the first method but the image on my phone was to big I'll try transferring to laptop then photo bucket |
Author: | SR20Datsun [ Tue Dec 13, 2016 3:04 pm ] |
SIck! |
Author: | Coz22a [ Tue Dec 13, 2016 10:17 pm ] |
More pics of Commer stat, it looks awesome!! |
Author: | SR20Datsun [ Wed Dec 14, 2016 9:11 am ] |
Build thread!!?? |
Author: | Bozo510 [ Wed Dec 14, 2016 12:49 pm ] |
+100 for build thread, no care given that it's not a datsun |
Author: | slo79b [ Wed Dec 14, 2016 1:04 pm ] |
It sounds too easy but really awesome! Would like to fit one to the 200b but will check the wiring. I'm pretty sure there is a warning light wire to the dash but the main feed wire is simple . Can any auto elecs comment? I'm a fitter and a spray painter but need more info on the electrical side lol |
Author: | Niscomm [ Sun Dec 18, 2016 10:42 pm ] |
Yes it was pretty easy to fit up you have the main feed then I branched off that to the S switch terminal and the L went to the dash light, as I have a dual battery set up that's how the auto sparky told me to wire it so now it produces about 14.5 volts which charges all the batteries. So if I were to post more info about the Commer would I continue here or start another topic? |
Author: | turbovan [ Mon Dec 19, 2016 7:57 am ] |
Cool bus! Start a new topic in this section - Members Rides - other Non-Datsun/Nissan: http://ozdat.com/forum/viewforum.php?f=83 |
Author: | banzai510(hainz) [ Mon Dec 19, 2016 9:09 am ] |
**** cool!!!!!!!!!!!!!!!!!!!! |
Author: | slo79b [ Mon Feb 20, 2017 10:13 am ] |
Hey guys, my original alternator finally died in my 200b so i tried the suggested alternator. I only needed to grind a touch off the inner alternator leg washer for it to fit over the original bracket. I needed to use a 940mm fanbelt instead of the original 915mm. I upgraded alt to batt wiring to 4 guage also. The original alt had a yellow wire going to the choke relay and on to the Brake Warning Light. I put power to this wire to make the light go out but occasionally it comes back on so i may have to recheck earthing and see why thats happening. Apart from that its charging perfectly, with the 2 wires L and S going to the Charge Lamp and a Power Feed respectively. |
