1600 extra wires in the loom http://www.ozdat.com.au/forum/viewtopic.php?t=34677 |
Author: | NUSTAD 510 [ Mon Nov 13, 2017 8:27 pm ] |
Post subject: | 1600 extra wires in the loom |
Hi all, Reassembling my 1600 which I bought in pieces. There are two "extra" wires in the loom near the drivers strut tower. One is a pair of yellow / green tracer wires into a single female bullet connector. The other is black / yellow tracer. I completely unwrapped the loom. These are definitely factory wires. Ive hooked up the starter, Alternator, oil pressure switch. Ony these two wires are left. Anyone got ideas? |
Author: | Nissanman [ Mon Nov 13, 2017 9:19 pm ] |
Post subject: | Re: 1600 extra wires in the loom |
Year of car?? |
Author: | NUSTAD 510 [ Tue Nov 14, 2017 3:17 pm ] |
Hi Graeme, Build date is march 1971. I think the car might have been an automatic originally. Trans tunnel seems bigger than my previous 1600 and it had a 3.7 diff. |
Author: | Nissanman [ Tue Nov 14, 2017 5:56 pm ] |
Well the BY may be for the starter inhibitor relay. If you can not crank the engine, then that wire may end up at the starter solenoid. The wiring diagram for an August 1970 is here: - https://www.mediafire.com/?t0932sd6ev7cu#yi8l6xjdnt1dy Page 34 is applicable. Mine is a January 1971 and this is from the owners handbook I got with the car |
Author: | NUSTAD 510 [ Tue Nov 14, 2017 10:49 pm ] |
Thanks Graeme, I'll hook up a battery and see where things are at. Cheers, Shaun. |
