It is currently Tue Dec 18, 2018 9:48 pm
Post new topic  Reply to topic  [ 120 posts ]  Go to page « 14 5 6 7 8 »
 Post subject: Re: Re:
PostPosted: Wed Jun 04, 2008 2:54 pm
Datsun_16_Hundred wrote:
Another tihng i noticed, when first looking at the dyno sheet was; it says gears: 4 ??
would that have anything to do with the wrong torque reading ?? 4 gears instead or 5 ?
5 gears, you would have a lower final drive ratio ??
or does the gearbox have nothing to do with it ?? ..lol i wouldn't know :oops:
it means the run was done in fourth gear, which is 1:1 on a sr20 gearbox.
as i just finished explaining, the torque reading isnt wrong, its just uncorrected.
the dyno roller size and gear ratio (and wheel size) affect the torque that the dyno reads.
what was wrong was my original understanding of what that torque figure meant.
PostPosted: Sun Jun 15, 2008 3:21 am
Datsun 180b Sedan:
Ca18det with port&polished head,
Steel head gasket,
EMS Dual Sport computer,
New Garrett GT2860RLS internal gate
Custom top mount exhaust manifold
Nismo lightened flywheel
4 bosch coil packs..
Big adjustable fuel pressure reg
New Bosch 044 fuel pump
intercooler 450x300x75,
210hp/157kw@6500rpm on a safe 12psi
Computer is holding me back a bit... :(
<- Datsun, the best buy in the long run.. ->
http://www.youtube.com/watch?v=Q7Ii6x-t_jw
PostPosted: Sun Jun 15, 2008 7:59 am
71 1600
SR20DET standard internals
182 rwkw @ 15psi
PostPosted: Fri Jul 25, 2008 5:29 pm
Hey MFP,
Just wondering if the L20B bottom end is standard ?
Head work ?
Camshaft ?
Etc.. cos im building an L20B with 40mm solexs bored out to 2.022L with 11:1 comp and 72 deg cam just trying to work out if 100hp is plausable :)
Stephen.
MFP wrote:
1600, L20B, 40mm Dellortos, 98 BP, Yokohama 195/50/15, BOC 3.9 diff, Street Torque Dyno Dynamics
My results from dyno night in Alice Springs 24.5.08. Datto 102.5 hp, GT-R 382 hp
http://youtube.com/watch?v=Dt-dzyusz6M
http://youtube.com/watch?v=OLUvFFIFqDg
Stephen,
Formally "Datsun_16_Hundred".
Thy Beast 1600
Datfusion
PostPosted: Sat Jul 26, 2008 10:14 am
69 1600
13b turbo
194 rwkw @ 12psi
Datsun 1600 13bt
KANARIS ENGINES 03 94623387
http://www.kanarisengines.com/
PostPosted: Fri Jan 29, 2010 10:50 am
Time for an update..........
Current set-up is:
SR20DET running 19psi boost
Strandard Crank
Standard Rods
Forged 10.5:1 CP pistons
Tomei Poncams
Adjustable cam gears
Cometic Head Gasket
Standard inlet Manifold
Standard Throttle Body
Custom Exhaust Manifold
Garret GT2876r (modified for external gate)
Tial 38mm External gate with screamer pipe
PWR Intercooler
740cc Nismo injectors
E85 Fuel from Power Plus
Motec ECU
Normally runs a 36mm restrictor which previously made 309hp. Quick tune yesterday with no restrictor for fun resulted in 400hp at the wheels.
www.full-throttle.com.au
www.boostcooler.com.au
Go hard or go home!
PostPosted: Fri Jan 29, 2010 12:21 pm
510 sedan
L18 - just started to blow smoke
small port a87 head
unknown lumpy cam
twin 40mm dellortos
s2 bb dizzy
extractors
2" exhaust
bb 5spd
3.7 r160
14"185 x 70 wheels
made 59 rwkw or 75 rwhp at barnes high performace,couldnt rev past 5000 rpm (dizzy malfunctioning) found out later that the alternator wire came off and was killing the battery :(
91 GT turbo legacy
GET THAT DATSUN DIFFERENCE!
PostPosted: Fri Jan 29, 2010 1:44 pm
MFP posted this back in 2008 so it might be a bit late to ask now
Quote:
Datto 102.5 hp
What other mods did this have? Raised comp? Fat cam?
EDIT: noticed someone noticed the same thing further up!
PostPosted: Fri Jan 29, 2010 2:43 pm
FJ20ET, 3" exhaust, k&n pod, microtech lt10s, 12psi. 155kw atw
PostPosted: Fri Jan 29, 2010 3:06 pm
S14 Jap Spec SR20DET (BB T28)
3" Stainless steel exhaust turbo back, CAT & resonator and Magnaflow straight through muffler
'Merge' type stainless dump
S14 factory AFM
Hybrid intercooler (600x300x76)
Greddy Pod Filter
TurboTech Valve (10psi)
Nistune ECU daughter board with conservative tune (safe)
Bosch 044 pump with SWR surge (Piergerg lift)
162rwKw.
(Got the AFM, still saving for Injectors, EBC, and perhaps a GT2871R turbo)
1972 Datsun 1600, S14 SR20DET Engineered (190-210kw @ 15-16psi.)
http://www.ozdat.com/forum/viewtopic.php?t=6579
M35 Axis Autech
PostPosted: Mon Feb 15, 2010 8:04 pm
s13 sr20det
t28 s14a turbo
GtiR quad throttle bodies
bosch z32 afm
siemens 570cc injectors
bosch 044
3 inch exhaust
factory airbox
avcr electronic boost controller
pwr cooler
nistune equipped ecu
202rwkw @ 18psi
PostPosted: Mon Feb 15, 2010 8:57 pm
1969 Datsun 1600
CA18DET
85.5mm CP Forged Pistons
NDC race bearings
Shot Peend Rods
ARP rod bolts
New stock mains bolts
ACL MLS head gasket
Ports cleaned up
Stock cams
Inlet butterflies removed
Stock FPR
460cc GTIR injectors
Z32 MAF
Apexi Super AVC-R
Stock exhaust manifold
Exhaust mandrel stainless system 2.5' to cat 3' from cat to xforce muffler 4.5 tip
Garrett GT2560R
Nistune with LM2 wideband
185rwkw @ 16 PSI with no air correction
Coming soon GT2871 with 700cc injectors and poncams with adjustable cam gears. Hoping for approx 250rwkw :twisted:
PostPosted: Tue Feb 16, 2010 8:36 am
Brad, you bought your turbo yet?
Wanna buy two at the same time (discount???)
Get me a price, and i might consider...
M35 Axis Autech
PostPosted: Tue Feb 16, 2010 9:16 am
Not yet Nik. Waiting for the dollar to do good things then will buy from a US dealer. I'll find out costing for 2 items. Cheers
PostPosted: Tue Feb 16, 2010 9:33 am
Thanks mate.
M35 Axis Autech
cron
