-- Datsun 1600/P510 Project by SR20Datsun -- http://www.ozdat.com.au/forum/viewtopic.php?t=6579 |
Page 2 of 77 |
Author: | SR20Datsun [ Fri Nov 11, 2005 8:42 am ] |
Post subject: | |
James, The Interior (cabin) was only bead blasted in the areas I told the guy to do it for the seam welding. Engine bay, and Boot area were all attacked with the plastic beads. The sound deadening tar doesn't come off with the bead blasting, and you have to remove it by yourself with a scraper and a spray bottle of metho....(lots of work) I left the sound deadener where the passenger seats go (pads of the stuff) but everything else went. I removed most of it around the boot area but wasn't to pedantic with it, as there was only pristine panel underneath. Likewise with the deadener underneath the car, because I had the car on a rotating frame I could access the deadener and remove most of it in the critical areas for the seam welding. A word of advice, REMOVE IT ALL!!! Nothing annoys me more than painting deadener over existing deadener and then having the old stuff fall off!!! As for the cost, I would have to refer back to the receipts, but I think a bonnet was around $60, and the boot was a little cheaper, so around $600. BTW, that is just a bare shell, with no glass, chassis components etc. PLUS, doors were paint stripped, and the bonnet and boot where bead blasted. |
Author: | SR20Datsun [ Wed Nov 16, 2005 4:08 pm ] | ||||
Post subject: | |||||
I have fitted a sealed battery to my boot, Here are a few photos showing the detail. I used 35mm^2 BOC gasses Welder earth wire.
Author: | dat16v [ Thu Nov 17, 2005 9:39 am ] |
Post subject: | |
Question in regards to the straps. Were they two pieces when you bought the box? The battery box I have has just the one strap going around it. Did you modify your strap? Iggy |
Author: | SR20Datsun [ Thu Nov 17, 2005 10:58 am ] |
Post subject: | |
That's a good question mate! What I ended up doing was modifying the straps so they would join onto the aluminium anchoring holders. So yes the strap was cut in two, and I got a place which specialises in canvas sewing to sew them up with crosses for strength. The only reason I ended up doing it like this is to allow the strap to go all the way around the box, but at the same time not actually going underneath the box and the aluminium tray. Plus with this design, the box really doesn't move around that much on the aluminium, but if it does, it isn't removing any paint!!! The aluminium holder was designed to pretty tight tolerances to hold the plastic box. |
Author: | dat16v [ Thu Nov 17, 2005 11:09 am ] |
Post subject: | |
Thanks! Now I can successfully 'borrow' your design! Iggy |
Author: | SR20Datsun [ Thu Nov 17, 2005 11:13 am ] |
Post subject: | |
No worries mate, Just make sure you get someone who can weld aluminium well. OH, and don't forget to drill the holes through the rear chassis rail under the boot (where there are two steel layers) as this will stop the thing from ripping out when you get airborne, or hit up the back etc.... Alternatively you can use some plate underneath the car for strenth, or some really big washers... PLUS, make sure you use a sealed battery... It's easier. |
Author: | datnat [ Sun Nov 20, 2005 12:44 pm ] |
Post subject: | nice nice nice |
VERY NICE. that is some inspirational body restoration. if you don't mind me asking, how much would you estimate you have spent getting all the body repairs done? including painting? looking forward to seeing more progress pics cheers tommo |
Author: | SR20Datsun [ Sun Nov 20, 2005 3:56 pm ] |
Post subject: | |
I have no idea on exact figures... (probably a good thing) I think it cost me around $5-6k. BUT I would really have to add it all up AND I did alot of the work myself (including paint prep etc.), and the painter was fairly cheap too. I think I ended up paying around $170 for a day at the booth. (mates rates) and the painter was around $30 an hour. This price would include: Fish oil Wurth rust preventative Clean and Strip disks Bead Blasting Paint stripper (and the strippers.... ) Body filler Welding wire/gas etc Sheet metal Thinners/Turps/Metho (for cleaning car) Paint -Primer, Final coat, Spray Putty Painter Sikaflex sealer Body deadener Rubber grommets... (ha ha) New glass (front and rear) Rubber kit (full kit) New head liner Carpet and anything else I forgot to mention. Oh and I have $5K of motor (SR20DET) sitting there waiting to unleash it's 167Kw... I should warn all that are out there, that this figure is fairly conservative, and like I said, I did everything properly. (so it will never have to be done again.) |
Author: | MR1600 [ Wed Nov 30, 2005 1:59 pm ] |
Post subject: | |
hey sr20 just reading your build up again So awsome the detail is so good Do you have any more pics you wanna share U said you had pics of it bare metal?? |
Author: | SR20Datsun [ Wed Nov 30, 2005 2:39 pm ] |
Post subject: | |
Yup, Bare metal on the rotisarie... Still have to find them and scan them in! Got heaps of pics, but just have to wade through them all and put 'em in. Still trying to remember what I had on the last members ride post! |
Author: | SR20Datsun [ Thu Dec 01, 2005 9:23 pm ] | |||
For those who are following at home: I have fitted custom Trico windscreen wiper arms. This allows me to purchase the current style of windscreen blades and just clip 'em in. These arms have a slightly uprated spring load, and blade to glass angle over the arc of wipe. This should mean that when the S14 Turbo motor is in, I should be able to hit some pretty good speeds before I get chatter. Thanx for these must go to the Test House guys at Trico Products Australia in Springvale Victoria (I used to work there as an Engineer). Pity the company is sweeping up and shipping out to China.
Author: | SR20Datsun [ Thu Dec 01, 2005 9:28 pm ] | ||
Post subject: | |||
I have also fitted a C210 Skyline rear view mirror. This bad boy was fitted with a new re-silvered glass because most of the C210 skyline rear view mirrors are pretty poor around the edges. The silver ends up falling off around the edges. Re-silvering cost me around $22 from Varga Bros in Nunawading (Melbourne) These guys did a TOP JOB! And I would highly recommend them for their quality work. The good thing about the C210 mirror is it's NISSAN! and secondly, SHE JUST BOLTS IN! -fully sik! looks factory AND you get the DIPPER!!!!
Author: | Bozo510 [ Thu Dec 01, 2005 9:40 pm ] |
Post subject: | |
One of the best 1600 resto's I have seen. A true testiment to your hardwork and attention to detail, keep the pics coming. |
Author: | Baz [ Thu Dec 01, 2005 9:44 pm ] |
Post subject: | |
Nice job there, looks very very neat. attention to detail has its rewards. love the visors |
Author: | MR1600 [ Thu Dec 01, 2005 9:54 pm ] |
Post subject: | |
honestly man what the **** looks like you got your hands on a 2006 model datsun 1600 a bit early... I envy all your work excellent attention to detail Whats you secret... Jealousy doesnt give any justice how i feel towards your project Please guide me to success "OB1" Keep it up |
Page 2 of 77 | All times are UTC+11:00 |
