It is currently Sat Apr 20, 2024 1:00 pm
Post new topic  Reply to topic  [ 22 posts ]  Go to page « 1 2
 Post subject: Re: Datsun Stanza 1981
PostPosted: Mon Apr 22, 2013 9:10 pm
good to see its being put to use to save another stanza :)
1971 B110
1971 P510
1974 H230
1974 B120
PostPosted: Mon Apr 22, 2013 11:19 pm
i honestly wish i could save both, but that's just how the cookie crumbles at the moment :cry:
__________________
Lara
~Datsun Stanza 1981
~Datsun 120y 1974
 Post subject: Re: Stanza GX 1981
PostPosted: Tue Apr 30, 2013 2:47 pm
Haven't done much lately because she won't start.
-changed batteries some were freshly charged. no noise or nothing..
turned fan belt still nothing..
Think it might be the starter motor again ( we thought we fixed the problem , rust around the leads cleaned it off put it back together started first go)
now she won't even start.. sigh.......
took the fuses out and replaced it from the other stanza i have so they're not brand new that could be the problem? although i stuck the old fuses in and still nothing. also... there is rust around the prongs that the fuses sit in. that could be a problem ...
looks like i need to take the starter out and give it a good clean...
__________________
Lara
~Datsun Stanza 1981
~Datsun 120y 1974
PostPosted: Wed May 08, 2013 1:44 pm
grab a test light and see if theres power at the wire that clips on the starter solinoid when some 1 is holding the key on the start position..
Doesnt matter if fuses have been used before as long as the fuse hasnt melted its inner wire..
The rusty tabs in the fuse box will need to be cleaned up
You can test the starter by crossing a screwdriver across the main power terminal on solinoid with the spade terminal that the ignition wire joins to on solinoid.. if this turns the motor over..your starter is ok.. and problem lays either in the loom / fusebox or ignition
68 510 - soon to be restored into a replica 68sss
69 510 - current build - L20b turbo
91 GT turbo legacy
GET THAT DATSUN DIFFERENCE!
PostPosted: Thu May 09, 2013 12:39 pm
Got the brother taking it into his work shop to test it out. it wasn't doing anything at first, then we tapped around the clip on the solenoid and then it started to make a click noise but still nothing. we took it out and put a jump starter to it directly and (i don't know the correct term) the inner drive/ thrust thing came out lol.. :lol: wasn't sure whether it was meant to turn or what, but anyways its all getting taken in to get checked
__________________
Lara
~Datsun Stanza 1981
~Datsun 120y 1974
PostPosted: Thu May 09, 2013 4:54 pm
Pictures of rust. Some are from distance and then Zoomed up
__________________
Lara
~Datsun Stanza 1981
~Datsun 120y 1974
PostPosted: Thu May 09, 2013 4:59 pm
(if anyone is wondering that's a toyota 1978 cressida in the back lol )
__________________
Lara
~Datsun Stanza 1981
~Datsun 120y 1974
