Nissan C80 http://www.ozdat.com.au/forum/viewtopic.php?t=33947 |
Page 1 of 2 |
Author: | Lurch [ Sat Oct 17, 2015 10:13 pm ] |
Post subject: | Nissan C80 |
I bought this off a kid out near Malmsbury in western Vic, a couple of years ago for $650.00 after being egged on by Graeme Harlor from NSW. Truth was that I'd been casually looking for a 'Tow Truck' for a little while & when this popped up I though 'that'd be perfect!'. How wrong I was... When I collected it, it had NO brakes, it over heated & once I got it home (a 4 hour drive through Melbourne!) it was in slightly worse condition than I expected Before I drove it home: Home: The mighty Nissan H30 engine! At some point in it's life it'd been used for carting Hay, as evedenced by someone standing on the roof to load the bales: This was going to be an issue - crack exhaust manifold: |
Author: | Lurch [ Sat Oct 17, 2015 10:29 pm ] |
Post subject: | Re: Nissan C80 |
I thought about my options for a few weeks, but the Ol' Boy had different idea's & persuaded me to crack on with the repairs... The brakes needed attention first & foremost and as the fronts were leaking, I removed them sent them off for reconditioning. I got them back with new Stainless sleves fitted - at a cost of $125ea. There are FOUR of them Next was the brake master cylinder, but this proved much easier & cheaper as it shares the same O-rings as International, Bedford & Dodge trucks of the same vintage, & I was able to reco them myself. At the same time I fitted new front brake hoses courtesy of Enzed. We bled the system, took it for a drive around the yard & immediately blew the rear wheel cylinders Nothing else for it - strip the rear axles down to access the rear wheel cylinders. At which point I got a surprise - curved wheel cylinders! I managed to find a Nissan part number for the rear wheel cylinders (NLA from Nissan), so a call to Auto Surplus was made & they were able to cross reference & find me some replacements O-Rings. Thankfully the cylinder bores were in VGC after a light hone & I was able to rebuild & refit them - I now had working brakes! |
Author: | Lurch [ Sat Oct 17, 2015 10:48 pm ] |
With the brakes sorted, it was time to concentrate on the over-heating issue. I attempted to back-flush the radiator, but I was getting an awful lot of mud & rust coming out & not a lot of water... Nothing else for it - I dropped the air scoop, pulled the radiator and took it into my local radiator shop for them to pull the tanks off & flush the core. An hour later I get a phone call from Big Jim from the Radiator shop: "you core's stuffed mate, but I can get you a new core & reco it for $530.00..." This POS is getting expensive... New radiator it was as I couldn't find a replacement or a different solution. When I removed the radiator hoses, the water pump outlet that the top radiator hose connects to had corroded away. The bearing was also a bit notchy. Thankfully as the H30 is the 6cyl version of the H20 4cyl found in Roadsters & Forklifts, new water pumps are easy to come buy - there goes another $100.00... I also bought a new thermostat while I was at it, as there wasn't one in it when I bought it! The cooling system now seems to have stabilized in temp, but a dose of Kero & water to flush out the block is in order... Next was the the cracked exhaust manifold to fix, & so I bought a new manifold gasket from Nissan in preparation: I removed the manifolds & then attempted to weld up the crack with a cast Iron welding rod, but sadly the material the manifold was cast from turned out to be un-weldable... We pushed the C80 into the shed & it sat there for 12 months or so while I tried to find a solution... |
Author: | green200b [ Sun Oct 18, 2015 12:11 am ] |
Looks good Lurch, keep the updates coming |
Author: | Lurch [ Sun Oct 18, 2015 8:46 am ] | |
Post subject: | Re: Nissan C80 | |
Oh, there is more to come Alister!----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- The C80 wasn't 'completely' forgotten however - the Ol' Boy's interest in it got the better of him. The C80 is stored at my parents place (I have no room at mine) & one night I popped around after work to find the Ol' Boy had replaced the broken side indicators with some Pajero items, fixed the non-working headlights, tail lights, front indicators, horn and a couple of other non-working electrical items. I got a bit enthused again, so I began the hunt for a replacement exhaust manifold OR a set of extractors. A common failure with the C80's was a cracked exhaust manifold, so on the few C80's I know what are running, they have extractors fitted (Graeme's in NSW being one). Phone calls to various exhaust company's yielded no results sadly I resigned myself to the fact that I was going to have to begrudgingly build a set of pipes myself, so I procured some H-series exhaust flanges via Lou the Datsun Roadster specialist, as well as a box of mandrel exhaust bends, & started planning... At the end of last year (2014) I happened to do some work with a pommy bloke called Tim, who as it happened was a bit of a guru at building exhausts & extractors. Tim was so much of a guru that he actually spent time working in Cologne, Germany for the Toyota F1 team building their exhaust systems............. So I booked him in earlier this year & we got cracking: 2 looooong days & they were finished. I learnt a lot from Tim & the amount he does just by eye had me surprised. After media blasting & a couple of coats of Pot Belly Black, they were ready to go on with the rest of the exhaust I built. |
Author: | Imago [ Sun Oct 18, 2015 10:26 am ] |
Something different. What's the H30 like to drive? Does it feel torquey and decent enough to use as a tow truck? Keen to see where this heads. Keep at it, seems like your old boy has more motivation than you ha. |
Author: | lampy [ Sun Oct 18, 2015 10:33 am ] |
Good work lurch, looks like it will be a great tow truck in the end. Nice lick of paint and the tray tidying up will make it look good |
Author: | d [ Sun Oct 18, 2015 3:34 pm ] |
I like these old things, Richard on 1000.com also has a couple he is using to display his 1000 ute I prefer the H30 and H20 almost over any datsun motor, they are tough as they come. http://www.tomeipowered.com/BTE/index.p ... tory/2546/ was a 3 time winner with this engine ))) In all honesty I thought the Cab 80 had the P40 engines like the Pootrols |
Author: | Lurch [ Sun Oct 18, 2015 6:01 pm ] | ||
Post subject: | Re: Nissan C80 | ||
It performs very well, lots of torque & it will rev if you want it to. I normally take off in 2nd gear as 1st is very short. 1st would be perfect for a loaded hill start.Keen to see where this heads. Keep at it, seems like your old boy has more motivation than you ha. 2nd to 3rd is a reasonable gap, but the gap from 3rd to 4th is HUGE, so you need some decent road speed & revs before you grab 4th. When I bought it, it sat on 100kph all the way home without a problem (apart from overheating). I should probably fit a Tacho... The Ol' Boy just doesn't want it sitting in the shed doing nothing! I'm motivated again, so progress will be made!
I don't own a vehicle with 'patina' Hayden, so guess where this is heading...
Author: | green200b [ Sun Oct 18, 2015 8:07 pm ] | |
Bare metal respray with House of Kolor custom mix?Hopefully not. What are your plans, more of a tidy up and then a banana-back tow truck? |
Author: | Stowers [ Sun Oct 18, 2015 8:51 pm ] |
This thing is awesome man I'll defiantly be checking for updates |
Author: | Lurch [ Sun Oct 18, 2015 9:37 pm ] | ||
Bare metal respray with House of Kolor custom mix?Hopefully not. What are your plans, more of a tidy up and then a banana-back tow truck? Yeah, more tidying up still to do Al, then clear coat the cab & then Banana back it |
Author: | Lurch [ Sun Oct 18, 2015 9:44 pm ] |
So the observant of you may have noticed in the photo above of the extractors being made that there is also a manifold in place & some Hitachi's in view... Late last year (2014) I happened to be speaking to an acquaintance of mine in Japan & in passing told him what I was up to. I mentioned that it'd be great to take advantage of the new extractors (when I build them) with some better induction, over the tiny downdraft Hitachi... A longer than normal pause occurred on the other end of the line... "I'll call you back in a couple of days." *click* A few days later, via a friend, of a friend... of a friend who had a heap of bizarre Nissan/Datsun 'parts' in Japan, I was able to purchase a very VERY rare manifold. What you see there is a triple side draft manifold to suit a Nissan H30! As it turned out, the manifold was 'apparently' originally fitted to a H30 powered Nissan President that was used for 'diplomatic duties' in Japan. When I received it, it was badly damaged - cracked in multiple places, bent & missing it's linkage arrangement. A few hours over a few weekends went into repairing it and getting it back into usable condition, and I already had enough parts in my collection to make a suitable linkage setup, Interestingly the bolt pattern is for 1.5inch Hitachi's (SU's) and I already had a set of twin 1.5inch Hitachi's from a Stanza SSS in my parts bin and a friend in Melbourne gave me the 3rd one, after which they were all reconditioned with 240Z needles & needle tubes. A couple of weekends ago I finally got a chance to install them on the H30, along with a custom fuel rail (made from 5/16 & 1/4 Bundy tube silver soldered together) and a heat shield I made from some 2.5mm Alum off-cut. (Not quite finished in this photo) So after all this effort, swearing & banged knuckles, it was time to hit the key... |
Author: | Anth510 [ Mon Oct 19, 2015 1:35 pm ] |
Very interesting, great to see something completely different. |
Author: | SR20Datsun [ Mon Oct 19, 2015 2:50 pm ] |
Awesome. The induction noises coming from underneath the cab are certainly going to be interesting. |
