It is currently Fri Nov 01, 2024 11:38 am
 Post subject: Datsun Laurel
PostPosted: Sat Feb 13, 2010 4:55 am
Here's what i just bought:
I have never ever seen one before in real life, seems to be in a pretty good condition.
Will do a lot of research before is start some basic modifications, new, better suspension, try to find new rubbers for everywere in the car, fix a proper carpet in it, maybe a modern engine or something.
Thanks for looking!
Eric
 Post subject: Re: Datsun Laurel
PostPosted: Sat Feb 13, 2010 7:14 am
that is sweet :thumbsup: :thumbsup:
Driving takes three abilities: Accelerating, braking, and turning.
More power only helps acceleration.
Lower weight helps all three.
PostPosted: Sat Feb 13, 2010 8:51 am
Sweet as. What engines do these thing have in em? L20A or L24? Or something entirely different?
Quote:
PostPosted: Sat Feb 13, 2010 9:07 am
Well, on the papers it says it is an 1800, so it must be some sort of 1800 engine, havent found an engine code yet.
It is only a four cilinder.
PostPosted: Sat Feb 13, 2010 9:15 am
Oh... I thought they were 6 cylinder engines lol. My bad. TRhey look long enough to have a 6 in em. Could be good engine conversion wise :)
PostPosted: Sat Feb 13, 2010 9:19 am
Just found this on another part sof the forum:
sbthomo wrote:
This is the first-generation model which debuted in April 1968. This car was developed to fill the gap between the Bluebird and the Cedric. The same suspension system as the Bluebird (front = strut, rear = semi trailing-arm) was adopted, along with the G18 engine, based on G15 that had been originally developed by Prince Motor. A 2-door hardtop version was added to the lineup two years later.
Laurel 1800 Deluxe B (1968 : C30)
So i guess it wil be a g18 engine.
There is plent of room for an l24 indeed :)
Or an rb25de, with itb's :D
PostPosted: Sat Feb 13, 2010 9:20 am
Yeah RB25 is what i was thinking :)
PostPosted: Sat Feb 13, 2010 9:24 am
I STOLE THIS FROM WIKIPEDIA
Quote:
G-18
5-bearing, short-stroke, V-type valve arrangement, multi-ball-type combustion chamber, the G18 employs an aluminum cylinder head and engine-performance.
The G-18 was a 1.8 L (1815 cc/110 in³) variant. Its 85 mm (3.3 in) bore was the largest in the range, and the 80 mm (3.1 in) stroke gave it good oversquare dimensions. It was an SOHC cross flow cylinder head design like the G-15 and produced 105 hp (78 kW) and 108.5 ft·lbf (147 N·m).
This engine was replaced in 1975 due to tightening emission regulations and replaced with the L18
Sounds like a fairly advanced engine for it's time; SOHC, Crossflow.
PostPosted: Sat Feb 13, 2010 9:47 am
Nice Laurel :) Where abouts are you located? Those registration plates don't look Australian.
PostPosted: Sat Feb 13, 2010 10:03 am
It's LHD too Al.
PostPosted: Sat Feb 13, 2010 11:19 am
If you're interested (and not in a hurry as I'd have to find it :roll: ), I have a workshop manual for the G18 motor. I think its a genuine factory one ?? Could be mistaken though ??
I can scan it and send a copy if you like.
EDIT: Found it - its only 36 pages, covers the G18 engine, fuel system, front suspension , steering and brakes for a C30. I was mistaken about it being Nissan, its actually a supplement to some other manual printed by "InterEurope".
PostPosted: Mon Mar 01, 2010 6:01 am
i am located in the netherlands, these are oldtimers dutch plates, and yes it is lhd.
dave: thanks for the ofeer bet i will be changing all parts from the supplement you have for newer, upgraded parts.
friend of mine bougt an s15 silvia, ill be taking his sr20de full swap from it for the datsun. no turbo, will try to get a set of itb's working with it.
had a look around to see if i could get some better suspension and brakes, seems like S13 parts will fit with some modifictations.
