It is currently Thu May 23, 2024 2:16 am
Post new topic  Reply to topic  [ 91 posts ]  Go to page « 1 2 3 4 57 »
 Post subject: Re: 1969 vh45 g130
PostPosted: Wed Apr 04, 2012 10:00 pm
[/quote]
Just as a side thought, are you going to be able to road register this thing?[/quote]
All vehicles originally weighing more than 1100 kg.
Naturally Aspirated - Original weight (kg) x 5.0 = max. capacity in cc’s
Forced Induction - Original weight (kg) x 3.0 = max. capacity in cc’s
I think those figures are current, however its QLD and as long as you find a guy willing to do the modplate you will be sweet. Its illegal to have a 13b turbo in an rx3 however guys are still getting them plated.
1971 B110
1974 H230
1974 B120
PostPosted: Wed Apr 04, 2012 10:40 pm
Ah ha, thanks for that Mitch! :thumbsup:
PostPosted: Thu Apr 05, 2012 8:54 pm
kolonelklink wrote:
I'm very impressed by the steering aspect of this conversion... if successful I think this is a great one-hit upgrade of brakes, column and rack... would you be comfortable with others applying your bracket designs?
Keep up the great work.
Peter.
I have no problem if anybody copies how i have done the steering/brakes etc. Thats what the internet is for. A large amount of how i figured out the steering was from searching the net and combining a lot of other peoples ideas into 1.
However - Dont go straight out and do what i have done just yet. Now that i have got this far with the steering and front hubs, i have figured out some ways it could be better, simpler, and possiby cheaper. Im busy with work for a while but in maybe 3 weeks i should have some time to try my ideas and post a few pics.
Also, while i was at the wreckers looking at steering boxes and suspension, i think i have come up with a way to move/modify the stock steering box to allow a v8, not a nissan, but a lexus at least
I think those figures are current, however its QLD and as long as you find a guy willing to do the modplate you will be sweet. Its illegal to have a 13b turbo in an rx3 however guys are still getting them plated.[/quote]
I have spoken to a guy that seems keen to do it provided it is all done correctly and safely. fingers crossed...
Plan B is a bit devious, but will work
Plan C is to drive it anyway, then just take it back to NZ where it will go through a cert no worries :)
PostPosted: Fri Apr 06, 2012 4:02 pm
Plan B.................Plan C.......Screw the man......... :woohoo:
PostPosted: Mon Apr 09, 2012 5:16 pm
Hey Fletch
this thing is looking awesome , might have to make a special trip to see it
looks like yourve got all the major stuff sorted
bugger you couldnt get the four pots on there , i garantee you can get them to fit!
PostPosted: Mon Apr 09, 2012 6:24 pm
Hey Ray,
big brakes would have made nightmare steering arms into impossible steering arms. I need to give Don the hurry up, and maybe black Pete with my top arms also.
Why dont you drag your cedric out of the shed? have you chased up a new turbo yet? you might as well scab the turbo off my other car. You only have a few months till calving!
PostPosted: Mon Apr 09, 2012 6:29 pm
Side note: This is my current office.
http://youtu.be/gfvt52VXync
Ill be finished comissioning shortly and hopefully will have lots of spare time to work on datto.
PostPosted: Wed Apr 11, 2012 9:56 pm
That looks... considerable
Did you make it yourself? :P
1973 H230 Wagon, 'ILL-260'
1975 911S Targa
1978 Torana Hatch
1999 GXE10
PostPosted: Thu Apr 12, 2012 8:41 am
Next time your over well pull an all nighter and just do it aye, ill supply the woodys
PostPosted: Sun Jun 24, 2012 10:07 pm
Did some work this weekend fitting a hilux diff. the stock h190 is strong enough, but the lowest ratio they come in is 3.9:1. the stock vh45 diff is 3.5 and i want to be as close to that as possible
First choice was r31 skyline wagon borg warner but, right size, and lots of ratios, but the only axles the right length are 4 stud. I got a hilux diff from the wreckers for 100 bux. i can get a 3.5 or 3.6 ratio lsd center for not too bad a price and they are strong as.
i cut the mounts off the h190 diff and cleaned up the hilux diff. I put the mounts on the leaves and sat the diff on top. once it was at the same angle i welded the mounts on.
The axles are massive compared to the h190 ones
Sitting in the car.
now i need to decide on brakes. i think i will keep the hilux ones as it will take lots of work to fit discs! and also order a recond lsd center with 3.58 ratio
PostPosted: Sun Jun 24, 2012 10:55 pm
Good work!
I can't believe the size of the Hilux axles bro, they look larger than the ones from the Ford 9 inch diff. :shock:
PostPosted: Mon Jun 25, 2012 1:28 pm
Would really be best to get them on a lathe and neck them down for most of the length to bring the unsprung mass down a bit.
Looking at the five stud axle flange... I'm guessing this is a 2WD Hilux diff? So the stud pattern already matches? How about the length?
1975 911S Targa
1978 Torana Hatch
1999 GXE10
PostPosted: Wed Jul 11, 2012 7:16 pm
Looks like its going to be a tonne of fun when its sorted! Massive credit to you for taking on such a massive conversion.
Do you still have the 280c alloy wheels that were on it in the first pics? I'm after the centre caps if you want to sell them.I'll be your best friend.
76 260c Hardtop.Its ugly,but its cool.
90 Hilux.Its just ugly.
PostPosted: Sun Jul 15, 2012 12:00 pm
sorry mate, only have wheels left and 1 centre cap. you can have them if you want.
PostPosted: Wed Jul 18, 2012 2:00 pm
Thanks anyway mate but i got a lead on a complete set.Cheers
