It is currently Tue Apr 30, 2024 1:26 am
Post new topic  Reply to topic  [ 64 posts ]  Go to page « 1 2 3 4 5 »
PostPosted: Fri Apr 06, 2012 10:06 pm
cant see any of the numbers but im going to have a wild guess and say L28 stroked with a diesel crank?
My garage:
180B sss (under restoration)
180b Wagon daily
PostPosted: Wed Apr 18, 2012 8:50 pm
Na i dont think it is that elaborate, but it is a L28 F54 block and P90 head, :thumbsup:
It is apparently build by a local, now defunct Z/Datto specialist. Based on this Im also hoping it has flat tops or ill have very low comp :roll:
It also has these hanging on the other side.... im not a fan of the pod filters at all so they will be gettin tossed for some trumpets and speedway style socks.
PostPosted: Wed Apr 18, 2012 9:18 pm
Wish I had that at my disposal :(
Those pods look so pox hahaha
1973 H230 Wagon, 'ILL-260'
1975 911S Targa
1978 Torana Hatch
1999 GXE10
PostPosted: Sun May 27, 2012 10:01 pm
You've been very busy Dave, you gotta show us some progress piccy's mate. :wink:
All the best, I'll see you soon!
PostPosted: Tue Jun 12, 2012 4:13 pm
As you wish my friend............
So far ive only been able to spend a few hours on weekends working on the wagon as family and work seem to take up most of my time these days.(who"s idea was it to start another project now)? Anyways hours with a sander and 80 grit has resulted in all the paint being removed from the bonnet, doors, rear quarters, tailgate and guards.
These were then covered in 4 coats of 3m hifill.
Next, underside of the bonnet, inside of the tailgate and opening, inside fuel filler well, inside of the doors and radiator support were sanded, primed and painted in the factory polar white.
This leaves the only the roof, door/window frames, cowl cover and A pillars to be stripped
and primed............ then i can start on the engine bay :shock:
PostPosted: Tue Jun 12, 2012 4:19 pm
Good progress :)
1975 911S Targa
1978 Torana Hatch
1999 GXE10
PostPosted: Sun Jun 17, 2012 5:35 pm
....................WARNING THIS POST CONTAINS GRAPHIC IMAGES..........................
So friday as 1 of those days where all the planets and stars aligned perfectly to create
a rare moment in time where there is nothing to do all weekend but indulge in your favorate passtime, what ever it may be, so i raced home from work and out to the garage for some S and M (spraying and masking)......................
5 minutes in and the plastic backing i was using to hold sandpaper on my grinder exploded
and took out the back of my left hand.There goes my weekend, **** to say the least..................
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
Fortunately its only a flesh wound with no damage to anything vital, bit sore and will prolly slow me down for a week and damn it scared the crap outa me.............
As you were.
PostPosted: Sun Jun 17, 2012 8:47 pm
Oh boy....nasty..... :shock:
Bummer man, it's a bitch when sh*t like that happens. Glad to hear it's not any more serious than it is.
Take care bro, see you soon! :wink:
PostPosted: Mon Jun 18, 2012 6:48 pm
Man that sucks!! i am always half expecting one of the cheap Chinese grinder accessories to come apart on me.
My garage:
180b Wagon daily
PostPosted: Thu Aug 02, 2012 7:06 pm
Hey guys, i figure ive done enough for a bit of an update..........
With my hand taking 4 weeks to heal due to "an aggressive, antibiotic resistant, infection"
and all of lifes other commitments it was mid july by the time i got back into the garage for some playtime but ive finally managed to strip the roof back to bare metal and get it in primer/hi fill, strip/clean and paint the engine bay and brackets, booster,lines ETC..... prep/paint the window and door frames and remove the head off the L28 motor.(more on that soon.)....
Roof in primer.......
Door frames in black.......
Enginebay before stripping and cleaning.........
Enginebay after strip and clean........
All painted up.....
Mark,(ozconnection) was kind enough to come over on a freezing friday night and reassemble my enginebay for me, THANKS MATE :hail:
While i was ripping the old auto box off the L28 i noticed it only turned about 350deg???
so i pulled the sparkplugs hoping for a miracle only to find cyls 3 and 5 full of water :shock: so while mrk was here we lifted the head off for a closer inspection, it wasnt good with heavy pitting and rust in both cyls, add rebuild to the list of things to do.
So it looks like i got duped on that "deal"
Now its wet rubbing time :(
PostPosted: Fri Aug 03, 2012 1:44 pm
Always glad to lend a hand Dave!! :D
Need some help with the wet rub? Text me when you've got some spare time and I'll try and be there!
That L28 wasn't stored correctly at all. Shame, it has all the right bits to be a solid mill. I'm sure you'll sort something out.
See you real soon. Keep up the great work mate.
:cheers
PostPosted: Mon Oct 01, 2012 9:33 pm
YIKES, only 5 weeks till the SDC show and shine........And with only 1 day a week to work
on the wagon its really 5 working days :shock:
Ive spent the last 8 weeks wet sanding the body with 800 and can finally say its ready for
paint, which i wanted to apply this long weekend but the weather isnt playing. Ive also dropped the motor and box back into the bay and begun reassembly with some help from my local cedric guru. :thumbsup:
This man is not a dentist, but i still cant show you his face :lol:
But this is some of his handy work
Next update it should have paint on it :wink:
PostPosted: Mon Oct 01, 2012 10:31 pm
...not my best angle... :lol:
Some great shots of the bay though! :thumbsup:
PostPosted: Wed Oct 03, 2012 11:25 am
Oh my god that looks awesome!!!
1975 911S Targa
1978 Torana Hatch
1999 GXE10
PostPosted: Wed Oct 03, 2012 1:13 pm
Now I'm sure heath is talking about the car and not marks butt :giggle:
1971 B110
1974 H230
1974 B120
