Hi Guys,
Thought i might post some pics and info of my bluey. here goes.
Started out as a 85' Series 3 TRX completly standard 90k on the clock, purchased from vic and then we drove it back to Adelaide, for the big transformation.
Traditionally its ca18 turn key..But i decieded to go the sr route.
Mods are as follows
S13 coilovers all round, custom laser cut camber plate.
Welded diff, new bushes, bearings, rebuilt rear calipers and slotted and drill discs.
Custom 3' tailshaft
R31 wagon fuel tank with gtr intank pump
s15 SR20det 6 speed
s13 engine crossmember including power steering
cazman industries adjustable castor rods
4 pot calipers
s13 swaybar
cooler
ally rad
nistune
apexi pod filter
32gtr wheels
fullriver drycell
plenty more things i have forgotten, car made 165rwkw with a suspected clogged exhaust.. car was built for datnats 11' which it made it too, drove there and back no dramas....
Currently in the plans are injectors/z32/e85 and a topmount turb.... soon to come.. heres some pics of the build..
![[ img ]](http://img121.imageshack.us/img121/7915/pa2900402.jpg)
Bay degreased ready for a quick cut n polish
S13 crossmember compared to the S3 bluebird crossmember, not alot of difference at all.
Fitting the s13 crossmember rear bolt holes are 4mm out and the front ones will need to be re-drilled and crush tube put in
![[ img ]](http://www.ozdat.com/forum/imagecache/27835/imgshk/img263/9899/p9290103.jpg)
By
shannonashman at 2011-09-28
By
![[ img ]](http://www.ozdat.com/forum/imagecache/27835/imgshk/img534/1978/p9290105.jpg)
By
![[ img ]](http://www.ozdat.com/forum/imagecache/27835/imgshk/img703/2304/p9290107.jpg)
By
![[ img ]](http://www.ozdat.com/forum/imagecache/27835/desmond/Himg210/server210/resmedium/p1220230.jpg)
