Hey All,
My first first post lol... so I have a Datsun 720 Ute fitted with an L20B A87 72 wade Match ported head manifold running twin 40mm side-draft dellortos, behind a 240k 5speed
I have a strange issue with the spark getting from the coil end to the distributor I am running which I believe to be a S2 BB Electronic dizzy... I have power to the coil from the ignition yet nothing by-passes the coing to power the dizzy, The dizzy itself is it perfect order it was running the day before last yet I have knocked a wire or miss wired the connections here on the coil end? I will upload photos either shortly or tomorrow to show the wiring config here yet it's so simple I think I'm over looking something simple I have checked all the fuse's none need replacing all fine powers getting where it needs too on the coil end yet no spark produced the key way in line right TDC etc the leads are fine plugs new only thing I can think of is the relays one under the drivers side blue 4 prong their is a harness for one like the one just mentioned yet nothing connected to it maybe was by passed at some earlier stage IDK :S Replaced the coil today yet nothing surfaced
any help much appreciate, thanks in advance
