Hey Anth,
Who did you do the PI track day with? I reckon you may go a little quicker if you <ahem> raise the car... Might not be riding on the bump stops then
![Very Happy :D](./images/smilies/icon_biggrin.gif)
HAhahaha.. Looks sick though!
PI was with PIARC, which I am a member of. Lot's of expensive machinery at their days, a bit daunting to share the track with some of them! EXE is more younger guys into Japanese cars, so I felt a lot more comfortable. Yeah I know, time to grow up and raise it, also want to get 50 series tyres next, which I think I've mentioned about 100 times haha. Funnily enough I didn't hit the bumpstops at Winton, but I did notice the front end bottoming out at PI, must be due to the faster/higher G corners. I guess I should re-install my rear bumpstops at some point
As above, your roll couple will also be very uneven unless you have corrected the excessively low rear roll center with that ride height. I bet it under-steers in to tight corners and over-steers out.
It looks awesome but there is some geometry changes that need to be done to be able to run that low and be fast
Yeah I know, it's not a race car so I've always comprimised between appearance and handling, although I am at the point where I'm willing to sacrifice some looks for more performance. It has 1" bump steer spacers on the front and a full Datsport rear end, but what I'd like to do is get the LCA point raised in the front crossmember. It actually handles quite well considering the height, but then again I'm no expert. I was understeering quite badly from my second session onwards, then my mate checked my tyre pressures and noticed they had gone up to 50psi! I had no idea about hot vs cold pressures, so after lowering them down to low/mid 30s the car was transformed, had so much more grip. At least I know now for next time.
Great looking car anth, dont raise it a millimeter, no matter what anyone says! And outstanding work on the build thread, great read.
Cheers mate, glad people enjoy reading it, makes the effort worth while
![Big Thumbs Up :thumbsup:](./images/smilies/icon_thumbsup.gif)
