It is currently Mon Jun 17, 2024 2:30 pm
 Post subject: 1600 intercooler options
PostPosted: Sat Nov 15, 2014 1:47 pm
Hi
I see there is already a SR20det radiator thread so I'll attach my question to that, but I am also looking at intercooler options as well.
I already have a Datsport radiator and a PWR intercooler custom mounted, but room in the engine bay is very very tight. I could not even change a fanbelt, or remove the radiator/intercooler without removing the SR (this might be normal anyway). I do not like the radiator showing at the front, must be behind the grill which it is now.
The radiator support was cut up pretty badly, so currently I am replacing it with another. I am not 100% with the setup I have, and want to do it right this time around.
So.... which intercooler and if you want, radiator is recommended?
PostPosted: Sat Nov 15, 2014 1:59 pm
Hmmm. I always thought the datsport system looked very clean when fitted correctly and worked very well.
I think it makes more difference spending some time to mount it all correctly and getting clearances correct,
Irrespective of which setup you use.
PostPosted: Sat Nov 15, 2014 3:13 pm
The Datsport would mount up nicely, if you use the Datsport cooler/radiator package I believe. The brackets on mine were changed, and custom mounted with the PWR, just seems really bulky in the front! I may buy the complete Datsport cooler/rad yet.
Last edited by Ackley Improved on Sat Nov 15, 2014 4:38 pm, edited 1 time in total.
PostPosted: Sat Nov 15, 2014 4:04 pm
I am running a pwr cooler in my 69 1600. I will have to get a custom radiator made up when the time comes. The cooler is quite thick and I will also need to cut out a large section of my radiator support panel. Maybe post up some pictures so we can see the space you have or haven't haha etc
Richard
PostPosted: Sat Nov 15, 2014 4:40 pm
Richard
Yes the cooler is thick, and once you add the radiator stuff gets tight. I think I will definitely not use the PWR cooler, but look for other options. You will need to cut a big portion out as mine currently is. I think there is a picture or two under my build thread.
PostPosted: Sat Nov 15, 2014 10:56 pm
I use a custom v n e rigoli cooler and pwr radiator and i have 1 pully left on my crank pully and had to shave the heads of the water pump bolts to get the set up behind the grille and there is probably 3 mm between my 16 inch spal thermo fan and my water pump but im very happy with my set up
PostPosted: Wed Feb 11, 2015 4:06 am
use a water to air cooler. no cutting, bending, twisting, hammering, punching, stabbing etc of the front end required whatsoever!
PostPosted: Wed Apr 22, 2015 2:15 pm
It has been a while since I started this thread, but it is now time to get back into the datto. I need this sorted. I am replacing the radiator support, and in doing so setting up the radiator/intercooler again, neatly. I have just ordered a bling radiator from Baz and need to get a intercooler. I came across this on good old ebay...
http://www.ebay.com.au.au/itm/400x300x6 ... 19fd0667c4
What do you think? That 10mm less in thickness might make for a little easier install, but performance difference between 76mm to 65mm core???
Other option is the Aeroflow intercooler.
http://www.ebay.com.au.au/itm/AEROFLOW- ... 5d4aa111cc
Time to get this show on the road!
PostPosted: Wed Apr 22, 2015 4:05 pm
http://ozdat.com/forum/viewtopic.php?f= ... er#p259386. looks perfect for a 1600, ill be buying one
PostPosted: Wed Apr 22, 2015 8:01 pm
That is the same intercooler in my first link. I will contact now about onr as well.
