It is currently Sun Apr 28, 2024 3:21 pm
PostPosted: Thu Feb 02, 2006 9:02 pm
hi all
can somebody please help by telling me the correct settings for an 1800 block with a 2.6 head
it is still running hot even with fans in the back
also looking to get a new cam.
what is a good cam for speedway use?
thanks
steven
PostPosted: Thu Feb 02, 2006 9:55 pm
2.6 head ?
U chop the back off an l26 :P
PostPosted: Fri Feb 03, 2006 3:46 am
You just mean 1.6 head?
Whats on the spark plug side of head? The # casting? 210 w53 a87. This makes a difference. In the states the stock early L16 were a 210 casting and best left stock.
The later ones had bigger valves and ports for better airflow with the SSS head being the best with the 1.5inch ports.
As for cams Ill let someone else anwser that one but I say get at least a 460 inch lift and some weber/mukuni sidedraft carbs or a weber DGES 38/38
daily driver get a 32/36DGV carb
rememeber new cams most need new rockers )or linshed. new lash pads of a different size and retainers, Cost is well say alot 2-300$ added if new then cost of rebuilding the head.
as for cam dowel settings I believe it came stock in the #1 postion but I put mine in the #2 dowel position for power sooner . 4deg adv #3 is 8deg.
timming the distributor is about 10 or with performance cam 12-15 (myself)dependong on the gas quality
http://www.geocities.com/dimer510canada/Heads.html
PostPosted: Fri Feb 03, 2006 9:19 am
hi
i bought the car the way it is.
my engine guy told me that it was a L18 block with oversized bored out pistons and a 2.6 or 2.8 head
i have no idea as to where to look to find this stuff out.
it already has a cam but it is the wrong type for what i need, it cuts in too late
if somebody can tell me where to look for whatever i will do that
thanks
steven
PostPosted: Fri Feb 03, 2006 12:52 pm
HIMMMMM some one was talking sh*t. 2.6 2.8 head???????? Never heard such a thing on a 4 cylinder L series
take a pen/pencil and go out to the car n write the #s down on the side of the head and tell us what it is?
PostPosted: Mon Feb 06, 2006 11:38 am
hi
the only numbers that we could find on the head are on the opposite side of the manifold
it says nissan japan
then U S7 or U 67
sorry but thats all the numbers that we can find
thanks
steven
PostPosted: Mon Feb 06, 2006 12:08 pm
the head would be U67 its a opened chambered head. with the cam i am not sure but with the timing set a base timing i think its 10 degrees BTC thne just drive it around then advance the timing then keep on driving it and keep on adjusting it a litte till its got alot more power and inturn it should stop running hot, also the problem with it running hot may be somethign with the cooling system
cheers
Ne one can restore a car it takes a real man to chop it
WotDat wrote:
And I think SSS 610 is either insane or has demonic blood in his veins. :rofl:
I am able to do general fabrication work mild steel, stainess steel, rust repair patches, catch cans etc. pm or email me at cording_da_revhead@hotmail.com
PostPosted: Mon Feb 06, 2006 1:43 pm
hi thanks for that
it will be a bit hard to drive around when we will be racing it at speedway,
but we will work it out now that we have a base to work from
check my site out below
http://nitrolineracing98.fotopic.net
thanks again
steven
Users browsing this forum: Google [Bot] and 6 guests
