Well last night I had some fun re-aligning the tang to it's correct position.
I developed a unique way to ensure that I had no.1 piston on a compression stroke: take the spark plug out of no.1, rip off about 10cm x 10cm of plastic shopping bag, double it over and place it over the plug hole, push some blue tac (about the size of a small marble) onto the plastic so as to seal the hole, then turn the crank by hand until the blue tac & plastic "pop" out of the hole
![Smile :)](./images/smilies/icon_smile.gif)
voila, we are now on a compression stroke. An inspection of the positoin of the dizzy also confirmed this.
I then lined up the notch on the pulley, & removed the dizzy.... the tang was definantly not lined up with the bolt holes - it was close, but certainly not within 5 degrees.
Unbolted the engine mounts, jacked up the engine, unbolted the oil pump (it didn't come right out as the sway bar was in the way like you said) - it slid out enough to disengage the gear, I then had to have my wife watch from above to determine if I had the tang lined up -after a few goes we lined it up, bolted the pump back in & then had a look - much better, the alignment of the tang was now just like the workshop manual picture showed it should be
Put everything else back together, tried to start the engine and ...... flat battery
![Sad :(](./images/smilies/icon_sad.gif)
- was too late in the evening to muck around trying to jumper it, so I'll do that this evening and see if it'll kick into life. *fingers crossed*
