So I had a day off yesterday. I call it a "mental health day" as I was going insane from doing NOTHING whilst something is fixed that prevents me from working. So i got stuck into my engine
When we left our hero he had finished re-installing the crank! So I got to putting the pistons in and this has seriously been the biggest C U Next Tuesday in the whole process so far. Basically you need 4 hands.
One to hold the con rod
One to slip the ring compressor over the piston
One to tighten the compressor
One to stabilise during the whole process
So i managed with two hands because im awesome.
Note to self - Buy 14mm socket to tighten con rod bolts.
So then the next step is head on, noticed a big tag on my head from the workshop saying "FINAL CLEAN NOT DONE" I thought best to inspect closely and sure enough, under the open valves were lovely metal shavings... that wouldve gone well in my bores! With all that crap removed and everthing shiny clean with a metho polish, head gasket on, then the head itself.
TA DA!
Threaded in the head bolts but again note to self - buy 14mm hex socket to tighten head bolts.
Next step, timing chain. Ive already timed the cam so that cylinder one is matched to the power stroke. Should be OK to just fit the chain, do a final check and its all OK. So I put the chain on, the guides on the chain tensioner... **** **** ****!!!! Sheared one of the chain tensioner bolts.
So until i figure out how to get that sucker out and find a replacement bolt... im stuck. So im thinking this weekend might be a good time to start pulling the Stanzas motor out. Mums given me the OK to use a carport space
