It is currently Wed Jun 05, 2024 3:47 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page « 1 2
PostPosted: Tue Jun 28, 2016 8:09 pm
Posted November 9, 2010 (edited)
Everyone has a photographic memory... Some just don't have film
Datsun 610/180B SSS FJ22 700 rwhp on E85
Datsun 810/200B SSS FJ20 (current build)
PostPosted: Tue Jun 28, 2016 8:17 pm
Posted September 20, 2012 (edited)
Hey Guys,
I havent been on here for a while... How is everyone?
The SSS has been dormant for more than a year now as Ive been caught up in other matters. Recently I have helped a friend build an SR20DET Gemini and it has bought back the thrill again. So a month or so ago I tinkered with the 180b and eliminated some alternator and voltage drop issues and got it running sweet.
And Im happy to say I have finally broken the 12 sec barrier and ran an 11.8 :D Booya
Time for more upgrades :yes:
Bigger cams, adjustable cam gears, 5 psi of boost, a 300zx box and a new tune coming up!!
and in the not too distant future a new EFI computer as Im only running a Microtech MTX-8
Ive also got my hand on some sexy JDM SSS rear lights, an early model grill and fenders to complete the look im going for
Id like to know peoples opinion on what direction to take in regards to a new computer?? whats good whats bad?
Also I have a friend who filled his chassis rails with expandable foam to strengthen his chassis...
has anyone heard of this? does it work?
One respectable source I know says yes, but Id still like to know what people think?
Fez
Posted May 16, 2013
Ok guys I haven’t updated my build since I was able to break the 12 sec barrier last year, and after doing so I’ve decided I NEED more power!
I looked into purchasing some cams for the FJ but found that it was very difficult to source a set. I know Kameari supply some but for the price I decided to go with a regrind. So the cams were pulled out of my spare engine and sent to Camtech at Chippo for a regrind.
Upon receiving the cams I had my engine builder custom make me a set or adjustable cam gears and away the car went to the mechanic to install the cams and adjust tappets. Which ultimately turned out to be a big mistake.... :(
Anyways after several weeks the car was returned and booked in for a Dyno. To my surprise the cams produced a great increase in power! with standard cams I was pushing 240rwkw, and after the cams were in I managed to push 280rwkw. a 40kw increase... I was stoked. I thought to myself that I should have done this long ago.
So I went to pick up the 610 from the tuners with the biggest smile on my face, had a good discussion with Adam from JEM about the car and went on my way. The datto drove so smooth and the power increase was amazing.
However! As I got to my home which is not far from JEM and entered the driveway... A mysterious rattling sound broke out and the car suddenly stalled :S. ignorantly I started the car again and the same sound was heard but this time much louder, I quickly turned the engine off as I was certain the sound was coming from inside the block :confused:.
I took off the spark plugs and inserted a magnetic rod down cylinder 1 and as I pulled it out to my surprise I found some metal pieces attached to the magnet. Upon further inspection the pieces were quite large and brittle, scratching my head I could not figure out what this could be as there should be no magnetic parts down there unless maybe a ring had shattered... But the pieces were too big to be a ring.
The head then came off and the hope of minimal damage quickly evaporated. the damage was enormous pistons were scuffed, the head was scuffed, cylinder 1 & 2 were scratched and all valves in cylinder 1 & 2 looked damaged. I could have killed someone at that point. But still I could not figure out what the foreign object was.
After thorough inspection I recognised that one of the valve guides in cylinder 1 was a little short... upon further inspection I came to realise that half the valve guide had broke off!!! It then fell into cylinder 1, got mashed up and destroyed cylinder 1 and piston, then some of the mashed up guide got sucked back into the inlet manifold and down cylinder 2 and managed to destroy that also.
The valve guides were standard but after speaking to a couple of experts they seemed to think that it was an unfortunate mishap, as it was unusual for valve guides to break, even for standard ones.
I put it down to the guy who installed the cams. I have a feeling that his clearances were off, because with further inspection of the head there were a few more bent valves and another cracked guide. And at that point a BIG lesson was learned. I should have taken the car to a specialist for cam installation or I should have done it myself! That’s what happens when you try and save time and money by using a cheaper option. Which I did not btw
Anyways back to the positives, the engine was pulled out and sent back to the engine builder for a rebuild.
a new set of 0.060 over sized Wiseco forged pistons
new bronze valve guides
new valves
valve job
baffled sump ( for some track action)
head ported and inlet matched
the block was shot peened and crack tested
springs and rods were fine so they were re-used
This was also an opportunity to finalise some other mods whilst the engine was out like
new custom ceramic clutch from penrith brake and clutch, as I was only using a heavy duty prior
new box install 300zx 5 speed (same as rb25) , with modified GTR bell housing to suit FJ and
custom made gearbox mount and dogleg shifter and new tail shaft to suit
new brake lines all round
relocate brake reservoir
camber tops
oil cooler
:yes:
The engine comes back this weekend and then the fun starts... This almost feel like when I first built the car, its enjoyable but a pain in the ass also as I am an impatient bastard.
Fez
PostPosted: Tue Jun 28, 2016 8:21 pm
Posted July 14, 2013 (edited)
Ok finally the car is back together
Here's some updated pictures
new wiseco's
Got the 610 running on Thursday and been trying to get as much Km's on as possible. Its booked for a Dyno in two weeks and fingers crossed I can rhit the 300+ rwkw mark on pump fuel @ 20psi.
PostPosted: Tue Jun 28, 2016 8:23 pm
That was a bit of an effort importing all that from Datnet
Will update with all the latest upgrades and pics in the near future...
