Geez Spandex ... comprehensive set of confessions
I thought I was gung-ho! Have always thought the prop shaft coming off at the gearbox at speed would be one of, if not the, most dangerous thing that could happen to someone in a car.....
Like the washer in the sump, that ain't no small washer, either
I have a recent confession to make .... its not related to cars let alone Datsuns (unless resting some of the components ON the shell of my 1600 counts?) but anyway. They have an auction every Friday down the road from where I work, .... there was this old lathe/drill/saw thingy that I was interested in and a 1960s Yamaha 100cc 2 stroke twin, didn't buy either of them but did buy .... wait for it ...... A SAFE. (what the !!
... bad attack of 'Auction Madness' , once afflicted you are never cured, take it from me. I think its related to Tourettes syndrome only it involves your arm jerking involuntarily into the air....). Anyway, said safe was 'only' $22
which is unsurprising since the tumbler didn't work and nor did the key and it weighed about 300lbs.
I figured maybe I could get the key to work (turns out the key is for the draw inside the safe, not for the safe door itself... so not much chance of that) ... so stuffed the thing in the back of the staion wagon and hid it in the garage, hoping my wife wouldn't notice! (didn't hide it well enough, one of my sons spotted it straight away and goes 'whats that dad?' ... right in front of Cath
Best case scenario I can get a new key and put all our 'valuables' (you know, wads of cash, gold bullion, diamonds in little leather pouches -oh , ok porn collection then) in there, so that the burglars can just take everything away in one handy unisured 300lb package rather than trashing the joint looking for stuff that doesn't exist.
I take the door off the safe, the cover off the inside of the door and check out the mechanism, .... interesting ..... and surprisingly simple! I take the cylinder lock out without any trouble. Take that brutally to bits using one of my favourite tools - the vice, then I put all the bits in a tray and put the tray in the safe , put the door back on and close it. The bolts shoot home with a satisfying clunk, as per the movies. I try to turn the handle and - you may have seen this coming - it won't budge..... what the!!
oh yes, nice one Neil, right up to standard - just forgot to put anything I really needed in there, like my birth certificate/passport etc, otherwise it would have been a really classic stuff-up, rather than a bit of a surprise for the guys on the forthcoming hard-rubbish collection (would they take it, I wonder?)
In an effort to prevent my biggest humiliation since dismantling a Rubiks cube and reassembling it in sorted order (audience impressed!!) then twisting it around a couple of times to a point where I couldn't get it back (audience rolling on floor in stitches
), I tried to recall which bits restrained the bolts from being withdrawn and I spent half an hour trying to release them with the tried and trusted bent coat hangar through the lock hole. After a while I realised access to half the mechanism was being prevented by the tray inside the safe, which just sits on 4 little perches. No problem , I'll invert the safe (cue a lot of grunting, clattering of dissasembled safe mechanisms, and a house-shaking thunk, unsurprisingly not dissimilar to someone hitting a concrete slab with a 300lb steel cabinet
). Thats cleared the impediment of the tray, anway, and wait .... furthermore (would-be safe crackers, please note), the handle now turns and the door opens!!!!!
Of course, after opening, the door now falls off its hing pins (not on my foot
), as the safe is upside down, and various latches, bolts, springs and washers roll out and drop through the immovable steel grill of the long drain that fronts the garage .............
Cheers, Neil.
