....Consider that if the S13 master cylinders can still be fine when upgrading the S13 brakes to R33 front and rear - capacity wise (even though an R33 m/c should be used) indont think that this/ setup should cause too much of a hassle....
Thinking and knowing are two different things. When it comes to brakes you don't wanna just think they will work ok, you wanna know.
The statement you made had better be made from fact, because every man and his dog may copy this, and may have sub-standard brakes. Pedal travel may be too large and not meet the ADR, pedal travel may be too small and not meet the ADR. etc... What this means to you or me is if we are driving the car, and all of a sudden there is an emergency, we apply the brakes but have to push 'harder than normal' to keep a certain stopping distance, which results in greater stopping distance, which results in an accident/fatality etc.
These systems are designed to work under a variety of conditions. As they are a system, if you change one small part of it, you may compromise the way the system works. Therefore by using 4 piston calipers from a hilux (for example) and single pistons on the rear, but using a MC (even if it is the right size) that is not suited to this system, you are jeopardising yours and others safety. So basically it is necessary to find this stuff out on paper first before the you know what hits the fan.
I would suggest you find out what the piston displacement is for the Hilux MC (from a known source) and the displacement is of the MC you are going to use, and if they are the same, you should be ok. Speak to your engineer to find out by how much they are allowed to differ. (I'd ask this first actually). The other thing is the leverage ratio of the Pedal acting on the MC. If this is different between the Hilux and the car you are putting your MC into, then the amount of travel the MC will go through is going to be different between cylinders.
The other thing you have to do is find out what size the piston is for the rear calipers you are using, and compare it to the Hilux.
An easier method may be to find out the amount of fluid displacement for the Hilux calipers, compare it to the 200SX/300ZX/GTR sumitomo 4 piston calipers and then say the MC that you are using is the same (or very similar) to the factory MC. That would be a good justification, and would keep the Engineer happy and keep you with safe brakes.
