I seem to be having a few problems with the motor.
1. Car stalls when taking a U-turn or some corners.
2. The flap on the carby doesn't close all the way. It's a few millimeters out from closing fully.
3. I took the standard air filter off a while ago and want to fit the standard air filter back on. I forgot how to connect the hoses back to the air filter. I have the thick engine air inlet all sorted, but i forgot where the vacuum hose connects to. (on the air filter it has 3 inlets, one for motor, one for vacuum, and another that has a point looking inlet)
**sorry i know what im talking about but its hard to explain when i don't know the right terminology**
4. I am tearing through fuel. I only get around 300ks per a full tank (if that). driving normally! I use unleaded 98 from BP and add the Valve Saver Fluid
5. Also the car used to keep running when i turned the car off, but i had my timing, points, leads and plugs all serviced like a month ago. I was told by a mechanical engineer to pour 1 Litre of Metho in the tank with a quarter of petrol to remove all the carbon build up around the valves (i only did this once). Not sure if this could be a problem with the car stalling
6. Is it normal for the car to stall when i turn it on and not rev it (the car is automatic)
Sorry for so many questions and i hope you understand, sorry I'm not that intelligent when it comes to cars, but I'm learning
