I guess its time for an update.
Since power is no longer an issue it was time to start working on improving handling. Since changing the front swaybar to provide clearance for the bigger sump (smaller diameter swaybar from SWR), the handling was badly affected - too much oversteer and not easy to control. So with the help of a friend of mine we decided to change the swaybar linkage to change the motion ratio instead of getting a new bar made.
I also decided to get the Bilsteins recoed and revalved after 15 yrs of copping abuse. Chopped the struts down a bit shorter to get some more travel as well. Sent the Bilsteins down to Baker's in Melbourne to work their magic.
Also got the shits with crappy DBA/RDA discs continually warping after track days so got some Project Mu discs sent over from a friend in Japan - no more issues in that area.
Pics of new swaybar link mount:
New link:
Fitted:
The changes made a huge difference next time out on race track and it was much easier and more fun to drive.
Spring rates felt a bit soft though, so went up in rate to 400lb/in in front. Measured the supposed 1100lb King rear springs and found they were actually about 850lb/in.
It's difficult to find springs that are properly rated to suit a Datto, so we decided to modify trailing arms to accept race style springs (smaller diameter) and also put in some height adjustment platforms. I dont have any photos of that setup but will try and get some up here soon.
Did another track day at Wakefield back in May and it was better again and ran a new PB so happy days.
2005 Mercedes AMG E55 350 kW
