Yeah hopefully! It sounds do-able. Bleeding the clutch isn't too hard. What you need to do is get someone lying under the car (person 1), and someone sitting in the car (person 2). Person 1 tightens the bleed valve on the slave cylinder, then person 2 pumps the clutch pedal abvout ten times, holding in on the floor on the final pump. Person 1 then loosens the bleed valve on the slave cylinder, and when all of the fluid has pissed out, tightens in. Do this three of four times and it should be ok. Then re-fill your master cylinder.
Good luck with getting it running!
Exactly as above. The only thing I would add is dont pump the pedal too quick as it may cause air bubbles to form in the fluid, thus defeating the purpose.
If you do this and it still isnt working, you must have a problem somewhere else (obviously). Have you got the arm on the master cylinder adjusted properly? i.e. to get full stroke on the piston when you depress the pedal?
Check both fittings on the line between the master and slave cylinder to ensure they are tight and not leaking air/fluid.
The only other thing I can think of is the master cylinder or slave cylinder may have 5h1t themselves and be leaking fluid past the piston. Check under the car and under the dash (could be interesting to get your tall carcass under their) and see if fluid is leaking out of the master cylinder.
Failing that, are you sure it isnt bleeding
and the problem doesnt lie with something else like the clutch arm, pressure plate etc?
Are you getting any movement from the pushrod in the slave cylinder i.e. is it trying to push the clutch arm, or not moving at all
This is usually a pretty ID10T proof job
What would you attempt to do if you knew you couldnt fail?
13B N/A powered 1600 racecar build (Built, not bought)
http://www.ozdat.com/forum/viewtopic.php?f=33&t=12316
Munch Munch, L series pistons for lunch
