The R33 rotors originally slip over the wheel studs on the outside of the hubs.
When used on S12 hubs (not sure about Z31), they are normally bolted onto the inside or backside of the hub - ie between the hub and the strut as per 1600 / 240K / etc hubs and rotors. The bolt pattern on the rotors is 5 x 114.3 (same as skyline wheels), but the required bolt pattern for S12 hubs is 4 x xyz (not sure as I haven't measured it up exactly yet). Basically, you need to modify the rotor to bolt onto the rear of the hub, rather than slip over the wheels studs on the front of the hub.
This is all dependant on how you plan to attach the callipers to the strut of course. I'm using Datsport calliper adapters on R31 struts and S12 hubs, which requires the rotor to be on the rear face of the hub. On the other hand, Jeff (SX-510) from memory uses them in "slip on front of hub" mode so would require no mods to rotor.
"Spandex" currently has a group buy happening for the correct rotors to use with S12 hubs.
Hey mate
Yep happy with the s12 setup. IE redrilling to suit 4 x 114.3.
I am curious about what work if any is required to fit an r33 gtst rotor to the z31 5 stud hub. I am getting conflicting info on this.
I might ring Baz and ask him what he does. Have emailed but replies tend to take a long time, understandably.
I am not sure on Spandex' prices (weren't they 280mm rotors?) but the best I have seen so far are from a group buy happening on Skylines.
http://www.skylinesaustralia.com/forums ... 00718.html
He is up about his 31st group buy(does one over every two week period). From memory slotted RDA r33 GTST (296mm) rotors were $260 including shipping.
He can pretty much get you any Nissan rotor you want.
He can also do greenstuff etc pads at very good prices.
James
