datsun 1600 fuel tank lines,which one is which http://www.ozdat.com.au/forum/viewtopic.php?t=16152 |
Author: | benjoeau02 [ Tue Feb 17, 2009 5:45 pm ] |
Post subject: | datsun 1600 fuel tank lines,which one is which |
iv got a datsun 1600 fuel tank , not shure which one of the pipes are what,,,breather or fuel line 8mm ? or 6mm ? please advise thanks |
Author: | Mad1600 [ Tue Feb 17, 2009 8:07 pm ] |
Post subject: | Re: datsun 1600 fuel tank lines,which one is which |
6mm return, 8mm feed. You might want to swap these if you are going EFI. Or even better replace the 6mm with 8mm |
Author: | benjoeau02 [ Tue Feb 17, 2009 9:15 pm ] |
Thanks for that ., Next month or two I will be putting a l20 around 180hp Will the 8mm line be good enough Thank again |
Author: | turbovan [ Wed Feb 18, 2009 8:40 am ] | |
Post subject: | Re: datsun 1600 fuel tank lines,which one is which | |
wrong the 6mm is the feed, 8mm returnYou might want to swap these if you are going EFI. Or even better replace the 6mm with 8mm only the 6mm one picks up from the bottom of the tank, the other one is higher in the tank. 6mm will be fine for your l20b |
Author: | SR20Datsun [ Thu Feb 21, 2013 9:41 am ] |
Chris, I assume for your twin scroll turbo fitment you are going to be changing this? |
Author: | datzenmike [ Thu Feb 21, 2013 12:54 pm ] | ||
Post subject: | Re: datsun 1600 fuel tank lines,which one is which | ||
wrong the 6mm is the feed, 8mm returnYou might want to swap these if you are going EFI. Or even better replace the 6mm with 8mm |
Author: | adriansk [ Thu Feb 21, 2013 7:31 pm ] | ||
Author: | hailest [ Thu Feb 21, 2013 7:39 pm ] |
I just realised I have mine around the wrong way after reading this post. OOPS! So will the 6mm feed be OK to feed the surge tank? Then onto the SR... Cheers, Trent |
Author: | nick [ Thu Feb 21, 2013 8:35 pm ] |
Not really but you could suck and see. The dyno will reveal any problems. If your fuel rail return line goes to the surge tank you might be ok as the surge tank is then not relying solely on the main tank for fuel. Best to try and replicate the same sized lines as the motor had in its original car for starters. Modified engines will need more thought... |
Author: | turbovan [ Sat Feb 23, 2013 3:38 pm ] | |
Chris,
No need to change it, you can flow quite a lot of fuel through an 8mm line, and a 6mm line pumping constantly is also enough to keep a surge tank filled.I assume for your twin scroll turbo fitment you are going to be changing this? Did 5 back to back full power runs on the dyno to test cooling and there was no issue with fuel. |
Author: | hailest [ Sat Feb 23, 2013 5:05 pm ] |
Interesting, will leave it for now and see how it goes Thanks for the advise. The engine is stock for the time being... |
Author: | butch510 [ Sat Feb 23, 2013 11:04 pm ] |
Could you just run all 8mm? Cheers, Richard. |
Author: | turbovan [ Sat Feb 23, 2013 11:39 pm ] |
Sure, but the pickup in the tank is 6mm so you would have to cut that out and weld in a larger one. |
