Once it has a cage you won't be able to street register it. There's some dispensation for drag cars using only a rear half cage, but full cages can only be registered in full blown rally cars and then the rego is limited such that you can only drive it during events, to and from events, to and from workshops for essential maintenance and in CAMS sanctioned parades. In other words it ain't a daily driver anymore.
They're called a "club permit registration" which are the maroon coloured plates in Victoria.
There is ways and means to get around building a cage. I'll PM you to discuss.
On with the cage itself. Buy the latest CAMS manual (from CAMS), refer to the relevant schedule (R ?) and it shows you the basic CAMS spec cage and the approved additions and in the text has the tube material, sizes and specs. I think it covers the maximum diameter reduction for the bends as well.
I'd check with a scruitineer before hand, but I'm pretty sure that with a standard CAMS spec cage if you've followed all the data, you can just get a scruit to come and check once it's built.
There's probably some paperwork involved with CAMS in getting the Roll Cage certificaion number and log book.
If you deviate from the book at all, KA-CHING $$$$, you'll need a full engineering analysis and then submit that to CAMS to get it Homologated. The includes if you want to change to Chromoly, or even TIG weld it I believe.
Also, if your fabricator wants to take to your roof with a holesaw to fully weld the front/rear legs to the main hoop, find a different fabricator. A truly decent fabricator will be able to weld it without cutting holes everywhere, I've seen some cages from the east that have had the roof cut, and it's just silly.
