Thanks once again for the feedback guys.
Lots of input there, but a bit much to cover at the moment, but we
will discuss them.
Managed to get to work for a few hours today to meet with our engineer.
We discussed various versions of radius rods & lower controls arms. Plus a few others.
Good news is that LH&RH threaded LCAs can be done street legal.
He will certify & approve them.
to start the discussion off please restrict the discussion to the Radius rods first, if you dont mind.
Then the LCAs next.
Three versions we can do. As mentioned in my first post All versions will have joints like
steering rack ends & be RH & LH thread adjusters.
V1 Pro:
lowest cost of the three.
Requires no mods to fit.
Better pivot point than common "U" bracket & rose joint set up.
V1 con:
Pivot point slightly further back than std set up.
Effective length of rod shorter than std.
tho better than rose joint method.
V2 Pro:
Pivot point further foward than V1.
Effective length of rod longer than std.
V2 Con:
Slightly dearer than V1.
May require opening up of the hole in radius rod bracket.
Will require drilling of 4 x 8mm dia holes in radius rod bracket
for retaining ring.
V3 Pro:
Pivot point further in towards center of vehicle.
Much longer rod than std.
V3 con:
most expensive. possibly up to twice that of V1
Requires removal of existing radius rod bracket & replacing with
new complete bolt in radius rod bracket.
Ok can we pick these to pieces please.
let the debate begin.
