This new crossmember for the steering rack , will it fit all engines (my guess is you have all this under control , but will ask anyway ) .
Will this one take over from the modified 200b crossmember in your handling kit . Will the bolts to mount the lower control arms on be moved in or out , moved in to use longer stock arms off another car or moved out to get camber with stock 1600 arms or use your new adjustable lower arms ? .
I just want to run a L series motor that will sit back and maybe down a few extra cm's , front end with some camber maybe with just stock arms off another car for road use like in the handling kit and be able to still run old 240k or 200b struts so I dont have to change my rims .
200B kit will continue for quite a while yet. has been upgraded with new transmount.
Reversed X member kit under development right now.
Steering rack kit to be resurected.
It makes sense for use to utilise as many components we make ( or newbits)
on all our kits.
Adjustments to allow for different struts & wheel offsets seriously being looked at.
some parts will fit std 200B & whilst we are planning the R&P kit for 16s & 180Bs
with some alterations may be suitable for 200B Stanza etc.
we have to get our wiring kits into full production first.
Except for the reversed Xmember kit. which will be 100% legal in all states.
