It is currently Tue Apr 30, 2024 12:26 am
PostPosted: Tue Oct 13, 2009 11:30 pm
Heya guys as promised im doin a quick wirte up of how i converted a sr s13 strut brace to fit on my datsun 200b
do this at your own risk, this isnt the best way nor is it the strongest but its the cheapest, quickest and it works, i will be getting new end plates made up but i wont worry about it till the ca18det goes in
now with the sr one you cant run the standard air box, i have put a short pod on there for the time being, i reckon if you use a ca s13 strut brace the kink would probably clear the airbox
so we start with the brace, i paid $10 for it hence why i didnt mind hacking it up but this is why i had to, as u can see the tower brackets are to close together even with the bolts set to its lowest setting it wont go in so we need to make something smaller
i was tossing up the idea about cutting the ends and retapping the bolts that screw in but wasnt sure how much that would effect the bar, also was a bit of a waste to put on a new bar too so i went with the drill the towerplates trick
first align the bar so it is even on both sides and then add another 5 cm to where you will drill so you can tention the bar mark this
pry open the sides of the towerplate to accomidate the ends of the bar to slip into it
as you can see it wont take much to get it to sit nice
now simply drill the holes, move the bolts in the end to align with the drilled holes and put the bolts through, tighten everything up and DONE!
a modified s13 strutbrace on your datto
Quigga
PostPosted: Wed Oct 14, 2009 8:53 am
Not bad,
but another way to do it if you have a round strut brace is to cut it down, then re tap the thread on it and bolt it back up, also you could of grinded off the tabs that hold the bar and then made some new ones and welded them on????
just some ideas.....
"You stay classy OzDat"
PostPosted: Wed Oct 14, 2009 9:21 am
yea making up new mounting points is gonna be the go once the ca goes in, but pretty much this was the solution to use it with minimal tools and time
PostPosted: Fri Oct 16, 2009 1:09 pm
i like that of course a tidy up later but would this fit a s15 sr in the engine bay ?
1600s arent the only datsun
PostPosted: Tue Oct 20, 2009 12:11 pm
yea i think s15 is a touch wider than s13 so you wouldnt even need to use this setup, you should be able to just screw out the end bolts OR mabes just put longer ones in alltogether, but srlsy man just buy a s15 brace you can find em for like 50 if you dont go and get a tien or whiteline one
PostPosted: Wed Oct 21, 2009 9:36 pm
yeah its in my 200b tho
PostPosted: Sun Apr 11, 2010 9:33 am
Sorry to bring up an old thread, but how long is an S13 brace at it's shortest adjustment?
Is the S15 one shorter?
BM510 wrote:
I'm a driver.
PostPosted: Sun Apr 11, 2010 11:59 am
Here is my s13 bar shortened for a 1600.
