It is currently Tue Apr 30, 2024 2:01 am
PostPosted: Thu Nov 26, 2009 6:29 pm
im helping a mate do a suspension upgrade on his sunny, we are going to use 200b struts with the ground control coilover kit, now most ppl shorten there struts to suit a z31 insert and get more travel,lower etc. well our problem is the 200b strut is already about 50+mm shorter than the sunny strut so theres no need to shorten them,
but we still want the benifit of running the shorter z31 insert plus theres alot more options with this insert, so what i was thinking is cut some 34mm(width of the insert) solid steel tubeing to make up the differance(think z31 are about 40-50mm shorter than 200b) place the solid bits of steel in the 200b struts first then fit the z31 inserts makeing it the same in length as the old 200b insert
can anyone see anything wrong with this?
-1969 1600 SR20
PostPosted: Thu Nov 26, 2009 6:53 pm
Yep you can space them up no worries.
But as you have coilovers you might as well cut the 200b struts down to suit the z31 inserts. You will be better off in the long run
PostPosted: Thu Nov 26, 2009 6:59 pm
cheers for the reply lampy,
we thought about it but dont want it to end up to low, atleast doing it this way first we can see if he likes the adjustment there, and if needed shorten them, but if we just go ahead and shorten them first we cant really go back if its to low if you know what i mean
-1969 1600 SR20
PostPosted: Fri Nov 27, 2009 7:56 pm
yep fair call
I have used spacers many a time and had no problems
PostPosted: Sat Nov 28, 2009 10:27 pm
these gabriel z31 shocks look good for the price - http://cgi.ebay.com.au/ws/eBayISAPI.dll ... K:MEWAX:IT
-1969 1600 SR20
PostPosted: Sun Nov 29, 2009 10:28 am
i have got two kyb exel g 200b strut inserts here from datsport if you wanted to go that way. They have probably done 300-400km before i took them out to change struts.
$80 and they are yours
Users browsing this forum: No registered users and 16 guests
