Time for an update........
Sunday 14th March
I finally found some time to get the car home this week, and have finally started pulling it apart to inspectthe damage properly. The more I looked, the worse it got
It appears the main reason forthe tyre rubbing was not the guard after all. The accident was big enough to actually bend the strut at the base and push the tyre onto the strut. So much so that the adjustable spring platforms (aluminium) have been worn flat, and the spring platform was virtually welded to the spring.....must have been hot in there! I think the shock is ok, but it is still stuck in the strut tube at the moment.... still need to figure out how to extract it.
So here is a list of known damage from the last race meeting that needs to be repaired........
1. Bent strut - Tube needs replacing
2. Wrecked Front Guard - Needs to be replaced, so flare will need to be done also
3. Damaged corner of bonnet (repairable)
4. Damaged Front apron - Will be replaced
5. Adjustable Spring Platform nuts on Strut - Need to be replaced
6. Grill - needs to be replaced
7. Panel across front of car (behind headlights) - Needs repair on LHS
8. LHS Rear flare - Needs repair (dented)
9. LHS rear Door - Needs repair (dented & big round black tyre mark)
10. Front Bumper - Replace if possible - repair if I have to.
11. Rear Bumper - Repair (straighten)
12. New Front Tyres
13. Front Springs - need to be rated, and then replaced if necassary
Other Must do jobs.........
1. Remove Diff and add more camber to LHS.
2. Repair snapped bolt in restrictor - Head of one of the bolts has snapped off, so the restrictor can not be removed. The bolt will need to be drilled out, but to do this I have to get it out of the car. To get it out, I need to remove the whole exhaust manifold, with turbo, waste gate & dump pipe in one piece.....that's going to be painful!
3. Remove sump & fix persistant oil leak
4. Fix oil leak (seeping) from drain on Turbo
Jobs I'd like to get done........... Brake upgrade! (might be the ideal time now the strut is out of the car).
That's it for now, but with a list this long we will probably miss the next round also and hopefully be back for round 4 in June.
