Thanks for all the replies. They have been great.
I did a bit of research and realised I should check the booster pushrod into the back of the master cylinder clearance. I had approx 2mm gap! So with a bit of white paint pen on the push rod, I adjusted and refitted the master cylinder multiple times, adjusting the pushrod each time until I got a little bit of white paint on the master cylinder itself. I then backed off the booster a touch and refitted the MC.
I then tried a different approach at bleeding. Yes I bled the MC 1st, then went LHR, RHR, LHF and RHF for bleeding order as normal. The only thing I changed was I got my wife to give the pedal a few good pumps between each bleed and hold more pressure on the brakes for each bleed off.
All I can say is what a difference! No doubt the Booster to MC clearance played a part. But I'm sure the change in bleeding tecnique was the big player.
Brakes are beautiful! Nice firm pedal and I require no pumping in between.
Oh and yes I always use a jar with fluid in it for bleeding
Thanks again all.
