1982 Stanza GX http://www.ozdat.com.au/forum/viewtopic.php?t=21482 |
Page 9 of 13 |
Author: | travm182 [ Mon Jul 16, 2012 9:50 pm ] | |
Post subject: | Re: 1982 Stanza GX | |
Not heaps big on the grill or steering wheel to be honest. I reckon any sporty looking wheel sorta suits them best.
haha i never did install that and i probably wont , better to have a stanza towbar in the shed incase of an emergency rather than a bluebird one But it's coming along great man. Impressive, maybe a pic or two towing something? *hint* *hint* Got my P's today! Also put the early taillights in |
Author: | Imago [ Mon Jul 16, 2012 10:38 pm ] |
Congrats! Should be keen... |
Author: | travm182 [ Mon Jul 16, 2012 10:59 pm ] |
ive been waiting so long haha it feels good |
Author: | travm182 [ Mon Sep 03, 2012 10:38 pm ] |
Still not painted.... weather is starting to get better and only have a few months left at school so watch this space. As for updates, the accellerator cable was really frayed so there was alot of friction in side the line and i ended up getting a perfect secondhand one and chucking it in and it drives alot smoother now! i just need to adjust the idle speeds so they sit a bit higher for gas and petrol. Nearly clocked up 4000km's since i got my P's!! Fuel cap is letting through a bit of spillage.. i need to make a thicker gasket. Massive hole in the exhaust.. welded up what i could without taking it off (its all seized together) So i will be building a new exhaust with extractors, sounds tough from the inside at the moment now though! haha The extractors should hopefully get it flow a bit better... Possibly building a custom LPG adapter for a single sidedraft weber soon, should give her a bit of extra grunt.. The Venetians are in now too. Have had alot of people stop to talk to me to tell me the learnt to drive in a datto etc. Still havent been pulled up by the cops yet! (its a bit loud and the color scheme is.. you know...) i think the fact that its a Z number plate means they dont bother cause its had a recent RWC. Anyway thats it for now! |
Author: | travm182 [ Sat Sep 29, 2012 8:03 pm ] |
Got my new Exhaust on Thursday! Lukey Extractors, 2inch, single tri-flow muffler at the rear. Sounds awesome! I also checked the timing (finally) and it was WAY advanced, so i set it to about 12deg and played around with the idle mixture and its now running beautifully, is flows so much better and there is a noticeable power increase now. Going to finish painting it when i finish school. |
Author: | travm182 [ Wed Feb 13, 2013 7:54 pm ] |
Havent updated this in a while! I blew a head gasket, i got a hole in the radiator and overheated it... whoops! Taught myself how to change the head gasket and did so over time, but an A87 head i had laying around on it so (so i can give the Datrally one back to its owner) Also bought a new 3-row Alloy radiator which fits perfect after enlarging one of the mounting holes. The engine is ticking which i think might just mean i need to do the valve clearances again. Also the heater hose at the rear that connects to the head has a little split in it so i need to replace that ASAP. Going to get it closer to painting stage when i get more time off work. |
Author: | travm182 [ Thu Feb 28, 2013 6:50 am ] |
So I fused the ticking noise, the manifold gasket wasnt sealed properly and was letting out a bit of air, which strangely creates a loud constant ticking noise. Glad it's gone now. Went for a drive and all went well there is no leaks in the coolant system which I am happy about! Want to drive it up to datnats so going to try and finish painting it, realistically I can't see that happening cause I'm working flat out but ill make it there in paint or in primer. |
Author: | Imago [ Thu Feb 28, 2013 10:30 am ] |
I'm not sure I understand this. 9 pages.on this thread and yet there are no rally or skid pics? I am dissapoint. |
Author: | travm182 [ Thu Feb 28, 2013 11:05 am ] |
They will come eventually! Haven't been driving it cause of the head gasket and now I've started taking it apart for paint |
Author: | travm182 [ Fri Mar 15, 2013 11:49 pm ] |
Bit of an update, i plan to have this painted before datnats so i can drive it up there (not entering it or anything). I rubbed it back and sprayed it with primer so it's now all one colour. This made it easier to see a couple of little dents which i will not be able to fix up. Theres only 3 or 4 little ones so im pretty happy with it. Then ill block sand the whole thing back with 800grit sandpaper. Also ordered custom plates! pics will come when they arrive |
Author: | travm182 [ Wed Mar 20, 2013 10:11 pm ] |
Car is finally a single colour! Just need to cut and buff which will hopefully happen on the weekend |
Author: | 2ndTimeStanza [ Wed Mar 20, 2013 10:43 pm ] |
Nice one love the colour |
Author: | k-man 79 wagon [ Thu Mar 21, 2013 12:13 pm ] | |
you would hope so nice build mate, always wanted a stanza |
Author: | travm182 [ Fri Mar 22, 2013 10:02 am ] |
New plates! Surprised they were available. |
Author: | travm182 [ Sun Mar 24, 2013 9:54 am ] |
Did a bit of colour sanding and buffed a couple of bits to see how they would come up. Its not finished yet i still have alot to do. The paintjob was not perfect, due to spraying it outside there are some places where specks of dirt or whatever dryed on the paint and stuff like that. Im happy with it though seeing as its the first time ive tried to spray a car. |
Page 9 of 13 | All times are UTC+11:00 |
