i'm up past joondalup... if you're busy that's cool, i have a few ideas anyway
i don't think it will be as hard as it looks... all the brackets are tacked on where the tabs slot over the U-channel, so it's really a case of
measuring up lengths, and where each bracket needs to sit in relation to the channel, taking the old ones off (which I can do after measuring)
and finding some U-channel (or bending some up), tacking on the new ones in the right place.
it's only the U-channel that's farked... and i measured it today, it's 20mm deep, 8mm across on the inside, metal seems to be about 1.5mm all round.
i'm going to call a few steel places tomorrow if i get time at work and see if anyone sells channel in those dimensions or close. i saw some aluminium
channel at bunnings today, but it's only 12x12x2mm ... it could work, but not sure if 12mm is deep enough to hold the glass with a seal in there too.
the other option is retrofitting something like a hyundai excel cable regulator... i know from working in spare parts how they work, they use two plastic
"grips" that the glass sits in, the plastic grips have metal eyelets that a bolt goes through to hold it to the regulator. the regulator is pretty much an
upright that bolts top and bottom, which shouldn't be too hard to make fit.. plus, they are cheap, and three supersessions/revisions later, they don't
break like they used to.
here's a pic of an excel one.. it has one bolt at the top, two at the bottom, and that white bracket thingy on the top right of the pic is where the glass
grips attach to... only thing i'm not sure of is the bend of the reg and how it will work with the shape of the 1600 door.
