So what Z box should I be looking for? Will the tail shaft need to be changed?
So the H190 is in all these models? 520,521,620,720,230,S12, 910, E20 and will bolt up except the S12?
Will the bluey disc still be ok to use?
Cheers for all the info Baz, the front end will be ordered form Datsport
Cheers Jay
None of the complete rear end assemblies will bolt straight in with the exception of the S12.
Tho as I mentioned previously, it does need some mods to get it spot on.
The H190 gear sets/ diff centers/ are in the other models to these will not always interchange.
The use of the carrier & gear sets depends on ratios, hemispheres,axle splines.
Bluey discs can be adapted to some, but not all.
Initially t'Racys Stanza will be using finned 240/260Z drums,
with air scoops & vents in the backing plates.
Tail shaft will need changing, depending on center or assy used.
Also if you use a 71 series box it will need shortening.
Any late 240Z or 260Z box can be use.
The early model 240Z can be used, but has a few hang ups.
we are also working on procuring clutch type LSD centers for H190.
