It is currently Sat Apr 27, 2024 4:58 pm
PostPosted: Fri Jun 04, 2010 5:10 pm
Roof Installation Datsun 510
can someone please advise of a procedure for fitment of a new roof lining to a datsun 1600 please??
PostPosted: Fri Jun 04, 2010 5:43 pm
You will need to remove the front and rear screens to do it properly
PostPosted: Fri Jun 04, 2010 11:26 pm
They are removed, I need tips on fitting the new lining.
PostPosted: Fri Jun 04, 2010 11:45 pm
I found the best way is work from the centre out. Do a bit towards the rear then move to the front and do a bit and so on until its all stretched out nice. Use big bull dog clips to hold it all in place. When you are happy with the way it looks break out the glue and glue it on bit by bit and put the bull dog clips back on until it's all dry.
PostPosted: Fri Jun 11, 2010 10:49 pm
Roof instalation for anyone giving it a crack... Not the most fun job but patience will sufface
Rods must be in correct order, to get best fit
Use contact adhesive, the yellow stuff. Make sure you paint it on both surfaces with a small brush and let it get really tacky before bringing together. Just glue around door and window frames... Dont stick to inside steel it should from the ceiling rods and be taunt to the window rubbers and pinch weld around the door jams
MYDATTO is correct with the bull dog clips. This is the easiest way ive found, as you can work in stages or come back and pull it tight in spots before you glue it. In most cars where theres a suspended headlining there is a small hook thats welded into the rear window frame center, use this to hook your last rod, this sets it up perfectly and the rest pulls tight towards the front
Always find your centers and tighten there back to front. Then work the sides down use extra glue on threads where uve trimmed it so it doesnt unravel down the track
In the rear pillar, cover any voids with card board and racing tape to give you a smooth surface. the panel is held up and reverse backtacked with a small section of cardboard, put a thin foam in and then pull it all down and glue in
Do the rest of the pillars by just folding the tops and glueing in
Trim up and sit back and begin drinking...!
I have patterns for 4 door 1600 if anyone is interested in a hood. PM me with that you want, many options available
Used in over 10 cars now, good fit and quality materials unlike cheap ebay rubbish
Good luck
Simon :thumbsup:
1971 1600 FJ20 Turbs
1968 1000 VB10 Deluxe wags
PostPosted: Sat Jun 12, 2010 1:35 pm
Has anyone considered making a hoodlining like they are made on newer vehicles? Not sure how to do it, but thought has crossed my mind.
It's basically a moulded (the tricky part) bit of cardboardy like substance with the trim glued to it. 'Paper mache' skills required?
Alternatively, does anyone use an extra lining under their hoodlining? It looks like something used to be glued to the underside of the 1600 roof.
PostPosted: Sat Jun 12, 2010 5:34 pm
yeah you can use the same insulation as you put under the carpet. Adhesive holds it to the roof mostly and the roof lining rods also squeeze up under it aswell...
PostPosted: Sun Jun 13, 2010 9:07 pm
Hopefully this pic works, this is my headlining from my car
[IMG]http://i677.photobucket.com/albums/vv13 ... ure189.jpg[/IMG]
I have some others but ill ned to search a lil more
Simon
PostPosted: Sun Jun 13, 2010 11:41 pm
There you go Simon.
I've got pics of your roof lining in my car but black doesnt come out too well in pics...
PostPosted: Thu Jun 24, 2010 10:01 pm
Thanks Nick,
I can never get pics to load up, thats why I gave up updating stuff on here
Nicks was one of the first I ever made up and turned out awesome considering its in a 2 door and we had a bit of guess work, but as you said black is hard to show up in pics
Ive since pulled mine out again due to constant paint touch-ups making it red :roll: . Hopefully another will be back in soon. Ive got it all ready just sick of things getting trashed while i work on other stuff and my shed is contantly filling with dust from the padock
Ill link some more in soon if you dont mind correcting the links haha
Simon :mrgreen:
PostPosted: Sat Apr 30, 2011 6:26 pm
Hey mate
just did my main roof section, and have a question.
do you have pics of this foam/cardboard business on the C pillars?
it would be most appreciated.
Ryan
