you chaps might know already, but there are a couple things to keep in mind with urethane
they shouldnt be used with trailing arms or castor rods, these bushes are supposed to flex, its a part of what they do. solid urethane replacements wont flex, which is a bad thing for these kinds of bushes
ive got urethane replacement bushes for my rear trailing arms in another car, the solution was to only replace one end of the trailing arm with urethane and leave the other end as it normally is, seems to work fine. when i adjust height i can hear it creak
the other thing is urethane bushes need to be lubricated now and then with white lithium grease or whatever the manufacturer recommends. if you dont, they can bind which causes creaking, one case ive seen personally is with an s13, you can feel the creak through the seat. they also squeak sometimes if not lubricated from time to time. ive heard binding bushes can affect handling adversely, i dont have experience in that though so i dunno
they do increase road noise in the cabin, whether or not its noticeable over the other noises in the car i spose depends on the car. rubber is a good insulator for that kind of thing which is part of the reason its used from factory, urethane on the other hand... isnt
the important thing to remember is urethane isnt always an upgrade, sometimes its better to keep it as it was from factory
not a lot of choice though nowadays hey
