Road car - saved from the metal crusher - this car was driven to a metal recycler and the plates handed in. The recycler rang one of the datsun places to see if they wanted to save it. I took it down got a blueslip with some minor repairs and I now use it to drive to and from the station.
It is a relatively clean rust free 79 jap spec car, engine number L16 00941. Since then I have put some old 260Z 14" rims that had from when I used 14's on the rally car and replaced the front struts with my old rally ones. The carby is a down draft webber.
Needs to have motor looked at next, it has a head gasket leak which I expect is a corrosion issue.
This is the most rust I have found in the car.
