Howzt.
Got a few pics of the parts in question. Been working on my "B"
Here a couple booster closeups.
7/8ths "Z" brake master cylinder:
15/16ths "ZX" brake master cylinder:
Both cylinders next to each other:
The bleeding nipples on the 15/16ths are very close to the strut tower. I will install the master cylinder this week. replacing brake lines as well.
Thanks for the theory Wisseys. Makes a lot of sense. I think I will use the 7/8ths to start with. I will keep the 15/16ths for further improvements down the road. When I install rear calipers to replace the rear drum brakes, then I will use the larger one.
The stock 180B master cylinder is a 3/4ths, so going up to a 7/8ths is a good step. Will update soon.
Cheers.
