1969 vh45 g130 http://www.ozdat.com.au/forum/viewtopic.php?t=28369 |
Page 4 of 7 |
Author: | fletch [ Mon Sep 17, 2012 8:33 pm ] |
Post subject: | Re: 1969 vh45 g130 |
Havent been up to much work on the car lately, been working away and moving house and other dramas Had the last few days of so been atacking a few things and moving to others when i get stuck or sick of it I was going to run r31 rear brakes but the handbrake cable does not really come out in an ideal place. I found some s14 rears for a good price. They have the cable coming out straight along the diff. Should work well. im thinking 290-300mm discs. |
Author: | fletch [ Mon Sep 17, 2012 8:42 pm ] |
Next up was the shifter cable. I want to keep it column change so i modified the manual changer and used a b&m shifter cable. Its pretty hard to change as the cable only has 67mm of travel. I have had to make a short linkage on the box and this has made it pretty hard to shift. also the cable is hard to move with the bends i have put into it. I have been told to try a more heavy duty cable so ill see how that goes when it turns up This cable bracket is semi permanent. if it works well its staying, a bit dodgy on the power steering motor but should be ok I might make the arm on the gearbox longer, it will be easier to shift, but i will lose 1st and 2nd gear. Its only a cruiser so maybe it will be ok, i will have to see what happens |
Author: | fletch [ Mon Sep 17, 2012 9:01 pm ] |
I kept the tunnel from the other g130 i wrecked. Panelbeating is harder than it looks! I will attempt to fit this somehow... I was going to run a hilux a/c pump, then i found a n14 pulsar pump (left) which was pretty short and nearly fitted in the top of the vee, then i was cruising the wreckers and found a tiida a/c pump (right). its a smaller diameter body and fits nicely up the side of the motor. About 20mm off the chassis rail so heaps of room... The water pump will be on its own belt and the tensioner is turned sideways so it can pull the belt tight The alternator is off a vh41. its shorter in the right places compared to the vh45 one. I will trim the top off it and if im lucky the bonnet will close. I will try it next week |
Author: | sutho510 [ Mon Sep 17, 2012 9:24 pm ] |
awesome build mate |
Author: | ozconnection [ Mon Sep 17, 2012 10:47 pm ] |
A build beyond words. Promise me you'll take me for a 'drive' in this Cedric when it's done... |
Author: | Hezath [ Mon Sep 17, 2012 10:52 pm ] |
Just been reading up on this on JNC hahaha Very nice! |
Author: | fletch [ Tue Sep 18, 2012 4:26 pm ] |
the bonnet shuts!!! Just had a test fit before i go out to work for a bit and one of the ribs touches the intake but thats it! 5 mins on the flapper disc will sort that out. Time for a celebratory beer! |
Author: | SR20Datsun [ Tue Sep 18, 2012 6:08 pm ] |
Sick to the power of rad. |
Author: | ozconnection [ Tue Sep 18, 2012 6:42 pm ] |
Great news about the bonnet. |
Author: | nebuchernezzer [ Fri Sep 21, 2012 2:28 pm ] |
I likes it! |
Author: | fletch [ Tue Oct 02, 2012 10:14 pm ] |
Shut bonnet! its missing some bits but its shut! Bought some NOS parts. Fairly big dent in the wallet Im looking into getting some custom windscrens made as they seem to be unobtainable. I have looked everywhere Got the accesories all connected up. Might get a 10mm longer belt on the AC and alternator as the adjuster is a little close to the ac pulley. Maybe just a smaller tensioner Need to finish the alternator bracket next New shifter cable has arrived and is much better than the one i was going to use. hope to fit that on my next break from work also. Then its onto the tunnel and then sump |
Author: | ozconnection [ Tue Oct 02, 2012 10:36 pm ] |
I still can't believe that engine fits in there...it looks HUGE!! Keep up the great work. Regards. |
Author: | wormtail1 [ Tue Oct 02, 2012 10:48 pm ] |
mad skills. Nowhere near as much work went into fitting the 25 in my cedric. Thats a real credit to you |
Author: | lampy [ Tue Oct 09, 2012 7:13 pm ] |
This is up there with the best builds i have seen on ozdat. Hope to see it running soon! |
Author: | fletch [ Thu Oct 18, 2012 9:05 pm ] |
Thanks for the positive comments guys, helps a bit when motivation is flagging... Finished alternator mounts so now the front of the motor is finished Next job is to locate a radiator. I can get a NOS radiator but it will be a bit expensive i think and maybe not up to the task? I know my mate fitted a VL one pretty easily so i think thats what ill do. Plus i have plenty of room! I have to do the sump and oil pickup next and somehow fit the transmission oil lines and filter past the exhaust, steering, and sump. Im away on a 4 week job near canberra starting sunday so ill leave you with this pic of my new hubbies! |
Page 4 of 7 | All times are UTC+11:00 |
